It is possible you are hearing peoplein skipland. skip is an atmospheric phenomenon that causes radio waves to travel hundreds even thousands of miles. there a lot of cb operators that run high power amplifiers which would make their signal go even further. this would mean you would hear them well, but your radio doesn't have enough power to reach that person. right now we are in a solar cycle which has been causing skip daily. if you know that the peson you are trying to talk to is local and within. a few.miles then there may be an issue wit either your radio or antenna. the antenna must be tunedto the radio or you signal will not radiate off the antenna completely. over time it can destroy the radios transmit circuit. so if you have never.tuned the antenna you may be causing the radio not to work well and you may have hurt the transmit transistor.
