The Learning Company Mavis Beacon Teaches Typing 8 (378683) for PC Logo
A
Anonymous Posted on Jun 27, 2011
Program won't run in Windows 7 - The Learning Company Mavis Beacon Teaches Typing 8 (378683) for PC
Anonymous
Level 2:
New Friend:
  • Expert 68 Answers
  • Posted on Jun 27, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
68
Questions
0
Helped
15980
Points
207
That program is very old; they're on version 20 or something like that, and may not be able to run on Win7 at all. (You really should just get an updated version. (v.15 is only $5-6))
The only chance of getting that app working under Win 7 would be to run the program with "compatibility mode" set to Windows XP... Or maybe even Windows 98 or 95 for something that old.
To change compatibility settings manually for a program, right-click the icon for the program, click Properties, and then click the Compatibility tab.
1 Related Answer
Debbi's Sewing Machine Repair
  • 7365 Answers
  • Posted on Sep 11, 2011
SOURCE: Trying to install Bible Navigator,
have you tried to install it thru the add & remove program in the control panel?
if you have & it didn't work -- try this---
go to my computer
go to the drive it's in
right click on the drive
click on explore
look for a setup or install icon & click on it & see if it will install that way
I had to install windows7 upgrade this way on my laptop
good luck
My keyboard on my Windows 7 PC starts acting crazy now when I went to type something. Instead of being able to type a letter, the computer wanted to open a program and won't act normal. What's
Run a full virus scan, and hook external keyboard to see if it will work, if okay the laptop keyboard will need to be replaced. Go to www.ebay.com type make and model of laptop, refine search to keyboard.
Bubble Shooter won't run
ok open the start button
control panel
system icon
tell us what the memory and cpu and number of bits(32 or 64) that this panel reports
1helpful
Cannot install MGI PhotoSuite4 on a computer running Windows 7 OS
The PhotoSuite 4 program is very old and won't work under Windows 7. http://sonic.net/mnitepub/pccafe/reviews/photosuite4/photosuite4.html says that the version 4 Platinum edition ran under Win95-Win2000 versions of the Windows OS. Thus even the compatibility mode probably won't help under Windows 7 32-bit. You can try it though by right clicking on the installer and then selecting Properties. In the Compatibility Mode tab, select Always Run this program in the compatibility mode and an older version of Windows. Then right click again and choose Run as Administrator. (You may have to do this again on the program itself.) Since Win7 64-bit requires signed drivers or programs, it is not as likely to work. (Check your version of Windows 7 by clicking Start > Control Panel > System and Security > System. If the title of your OS ends with x64, you have the 64-bit OS. Otherwise, you have the 32-bit OS.)
If you have Windows 7 Pro or Ultimate (or upgrade to one of those versions), you can run a virtual version of XP for free. Download and install Microsoft's Virtual PC and then XP mode (in order). This works best if your CPU supports virtualization and you enable the feature in your computer's BIOS. (There are work-arounds for computers without virtualization. See the MS support pages.) Install your PhotoSuite inside the virtual XP program in that case.This old software may run in that case. (However, I've had some Win2K software that ran under XP with the compatibility mode but didn't run under the virtual XP. Note: virtual computers do have some additional limitations. They do not talk to the host hard drive and other hardware directly. (You can install a printer on the host machine or the virtual machine but not both.) You'll need to save files on external media (flash drive, optical disc or other hard drive) to transfer them between the machines).
Another option is to run an older version of Windows on another computer, as a dual boot computer or with Virtual PC (or another virtual computer package - VMWare or Parallels). In that case, you need a licensed version of the older Windows OS. Again install the program while running the older OS.
The final option is to upgrade to a Windows 7 compatible Photo editor and organizer. (Even the Microsoft Windows Live Photo Gallery has some of the features of Photosuite SE.)
I hope this helps.
When I try to install the program, it says that I may to use a 32-bit system. I have Windows 7, 64-bit. Does this mean that the game won't work on my computer?
Maybe so. As alot of programs and software still recognizes windows xp and not windows 7. I have encountered alot of similar problems with windows 7 and the same program runs well with windows xp.
thanks,
G.
I tried to run the HP Deskjet F-380 Installation CD on Windows 7 64 bit and I get the message that my system won't support it.Windows Vista didn't have any problems so what gives?
Instead of using the CD:
1. Unplug the printer from the computer.
2. Download the driver at the by clicking here. Let the program run and finish installation.
3. Reconnect the printer and Windows will auto detect the printer.
I recently got a computer with Win 7, and everytime I try to use my Eurotalk Hawaiian, The program won't work, It loads but it won't play the games or the word reviews. How do I fix this?
This might be due to software compatibility issues with Win 7.
Try running the program in "Windows 7 Compatibility Mode", there are not assurance it will work. Hope it work for you & good luck.
Here are help available at these link below:-
1. http://www.sevenforums.com/tutorials/316-compatibility-mode.html
2. http://windows.microsoft.com/en-US/windows-vista/Make-older-programs-run-in-this-version-of-Windows
Hope it helps.
How can I run my old copy of Monopoly from Infogrames on Windows 7?
Works in my Gateway Netbook running a Win 7 Starter OS, Won't even install on my Dell N5010 running a Win 7 Home premium OS. BUT IT does work in Safe mode on the Dell laptop. Tried compatibility mode. Have no Idea why it won't install.
Sybase Powerdesigner 9.5 Windows 7
PowerDesigner 9.5 wil load on Windows 7 but it won't run. I was able to get it to run by installing it in the virtual XP environment on Windws 7.
For this to work,
Must be running Windows 7 Professional or better, and
Your machine has to allow virtual machines (BIOS Setting).
You will need to download 'XP Mode' and indows Virtual PC' from Microsoft.
http://windows.microsoft.com/en-US/windows7/install-and-use-windows-xp-mode-in-windows-7
You will be able to run PowerDesigner 9.5 and oter applications that will not run in the Windows 7 environment but ran previously in the XP environment.
Top The Learning Company Computers & Internet Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a The Learning Company Computer and Internet Expert? Answer questions, earn points and help others
