Polaroid PoGo Digital Photo Printer Logo
Posted on Jun 27, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have re set the date using the set up menu. It appears correctly on the screen as todays date 27/06/2011 yet it is still printing as 01/03/09 when I select the print date option on the photograph. The camera has been turned on and off since re-setting the date. Im hoping I'm simply being stupid! Please help!!
Anonymous
Level 3:
  • Master 910 Answers
  • Posted on Jun 27, 2011
Anonymous
Master
Level 3:
Answers
910
Questions
Helped
306636
Points
2616
The print date option is the date the photgraph was taken, not the date it was printed.
During setup an incorrect year and time entered. how do I reset them
Setting the date and time in Windows 10
Note: Windows 10 automatically adjusts your date and time for you and only allows you to adjust the time if you disable this feature. If the wrong date and time is being set, you may need to change your time zone, or if you want to increase or decrease the time for other reasons, follow the steps below.
Right-click or tap on the date and time in the Windows Notification Area in the bottom right corner of the screen.
Click Adjust date/time.
Make sure your Time zone is set properly if your computer is displaying the wrong time.
To manually adjust the time, turn off the Set time automatically option and then click the Change button.
Setting the date and time in Windows 8
In the lower right-hand corner of the screen, click or tap the Windows Notification Area where you see the date and time.
Select Change date and time settings... in the bottom of the window that appears (shown below).
Time and Date in Windows 8
In the Date and Time window, under the Date and Time tab, click the Change date and time... button.
Make your adjustments and click OK.
Click OK on the main Date and Time window to save the changes.
MacOS
Choose Apple menu > System Preferences, then click Date & Time.
Click Date & Time, then set the date and time automatically or manually.
Automatically: Select “Set date and time automatically,” then choose the network time server for your region.
Manually: Deselect “Set date and time automatically,” click today’s date on the calendar, drag the clock’s hands to show the correct time (or enter the time), then click Save.
Click Time Zone, then set the time zone automatically or manually.
Automatically: Select “Set time zone automatically using current location.”
Manually: Deselect “Set time zone automatically using current location,” click a location on the map, click the Closest City pop-up menu, then choose the city closest to your location.
Click Clock.
Show date and time in menu bar: Select the checkbox to see the date and time in the top-left corner of the menu bar. In “Time options” and “Date options,” set how you want the date and time to appear.
Announce the time: Select the checkbox to hear the time announced, then choose when you want it announced. If you want, you can customize the voice.
How to turn off time/date stamp on finepix s1850
Seeing the Date When Previewing images
  • The camera records the date and time of each photo in the metadata attached to each picture. You have the option to see the date and time when when the camera is in "Playback" mode, which allows you to preview your images on the screen. When looking at your pictures, use the "Disp/Back" button to include text with your pictures. The date and time will appear along the bottom of the image.
Printing the Date on Pictures
  • Users can include the time and date on their prints from the "Mode" menu by choosing "Print Order" with the "With Date" option.
2helpful
Trying to set date/time for the first [ what is the wrench button?]
The "wrench" is NOT a button, it is an icon in the menu.
Press the MENU button. Press the Right/Left button to select the "WRENCH" icon The Setup menu appears in the center of the LCD. 3. Press the Up/Down buttons to select the Date option in the Setup menu. Press the MENU button. Press the Up/Down buttons to select a Date option from the Menu that appears: On selecting "On" the date will appear on the photo once it is taken. • On selecting "Off" no date will appear on the photo. • On selecting "Set Date" the Set Date settings screen will appear. You will be able to • change the date settings that will appear on the photo once it is taken. To Set the date: Press the Up/Down button to enter Set date option. 1. Press the MENU button. 2. Press the Right/Left button to select and highlight the Year, Month, Day, Hour, Minute, 3. Second and Date Format type. Press the Up/Down button to set the Date, time and format
1helpful
I do not know how to set the time stamp for my FUJIFILM S1500. The date appears on the display screen when I view the pictures I have taken, but no longer appears once I download them to my computer??
The Fuji FinePix S1000FD camera supports time stamping only when printing pictures via USB with a printer that supports PictBridge. Otherwise, you will need to download the images and use an application such as "Visua Photo Time Stamp."
To print with PictBridge,
  1. Connect the camera to the printer and make sure the printer is on.
  2. Press the right-pointing arrow and hold for a second or until the USB logo is displayed on the camera
  3. Press the DISP/BACK button on the camera
  4. On the menu, select the PRINT WITH DATE option and press MENU/OK.
  5. Press MENU/OK again to start printing.
2answers
My camera shows that the date and time are set up but date does not print on picture when developed. it's a new camera and I just developed my first set of prints and there is no date on any of them. ...
On digital cameras, the data is stored with the filename. Check the back of your prints to see if the dates were not printed there. Most companies do put at least the date information on the back of the prints as well as any other metadata stored with the file produced by the digital camera. Unlike film cameras, which could only record the date by actually putting it on the picture, digital pictures contain metadata that can include things such as people tags, location tags (geotagging), etc. depending upon the capabilities of your camera. The date and time is always stored along with the filename on all digital cameras. If the company that printed your pictures did not include the date on the back of the picture, ask them if they can do it or find another source to print your pictures that can.
If this did not address your issue, please reply with any amplifying information so that I may more accurately address your issue.
I hope this helped!
9helpful
2answers
I have a vivitar vivicam t324, i cannot find where to set the date and time. please help.
hit the M key scroll over to were it says setup srcoll down its between digital zoom and auto power off it will say date
2helpful
How to select date stamp on canon powershot a640?
You can print the date on image when Postcard is selected. The date will be printed on your images even if it has not been set at the computer or printer.
* Ensure that the camera's date/time is set beforehand.
* Set the camera to a shooting mode (except (Stitch Assist) or Movie).
* Press the <DISPLAY> button so that icons show on the LCD screen.
1. Check that appears on the LCD monitor.
- If it does not, click here to view the procedure for changing the resolution.
2. Press the <MENU> button.
3. Select (Date Stamp) in the [ Rec.] menu using the or buttons.
4. Select [Off], [Date] or [Date & Time] using or .
5. Press the <MENU> button to exit the menu.
6. Shoot the image.
- The Date or Date & Time will be embedded into the actual image.
Can not get dates to show up on photos
You can embed the date on image data when (Postcard) is selected. The date will be printed on your images even if it has not been set at the computer or printer.
6. Shoot the image.
1helpful
Lost my manual
DatelTime Settings
1) Set the Power Switch 4D to "1M!" while pressing
down the Lock Button (I) located on the switch.
2) Press the MENU Wheel 0 in. The Menu Screen
appears.
3) Rotate the MENU Wheel 0 to select
"~TO SYSTEM MENU" and press it to display SYSTEM MENU. Rotate the MENU Wheel 0 to select "~NEXT" and press it to display the next page.
4) Rotate the MENU Wheel 0 to select "DATE/ TIME" and press it. The DATEITIME Menu appears.
5) To set "YEAR", "MONTH", "DAY" or "TIME" (hour/minute), rotate the MENU Wheel 0 to select the desired item, and press it. When the setting begins blinking, rotate the MENU Wheel o until the correct setting appears and then press it. The setting stops blinking.
6) When none of these settings ("YEAR", "MONTH", "DAY", "TIME") blinks, rotate the MENU Wheel 0 to select "~EXIT", and press it. The Menu Screen reappears with the highlight bar on "~RETURN".
7) Press the MENU Wheel 0 in to close the Menu
Screen.
. To display the date and time in the camcorder's display and on a connected TV, see DATEITIME
DISP. (U pg. 21) in SYSTEM MENU.
. The date/time cannot be stored in memory if the built-in clock battery runs out. Consult an authorized JVC dealer for replacement, or set the date/time as necessary before you start shooting.
2helpful
How do I get the date to print on the pictures
To set datestamp to appear on your pictures:
Hit FUNC SET (middle of wheel on back)
Hit Right side of wheel to SELECT the mode you would like to have (Auto, Man, etc)
Hit Bottom of wheel to get to bottom of Left Menu on screen
Hit Right side of wheel to SELECT fifth selection (Postcard 1600x1200)
This is the only mode I have found that supports the date stamp on the Canon Powershot SD600.
P.S. Don't forget to set the correct date and time in the screen MENU under the Tools tab!
Top Polaroid Office Equipment & Supplies Experts
Sean Wright
Sean Wright
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Polaroid Office Equipment and Supply Expert? Answer questions, earn points and help others
