Archos 101 Internet Tablet 16GB 10.1" Android Tablet (1671641000) PC Notebook Logo
Posted on Jun 27, 2011
I reformat my archos 101 tablet, now all the files are gone, when I turn it on all I see is Archos A101IT Recovery, can you please help. Thanks.
Anonymous
Level 1:
New Friend:
  • Contributor 8 Answers
  • Posted on Jun 27, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
8
Questions
0
Helped
3735
Points
29
If your ARCHOS does not respond correctly or does not start properly, you can try to remedy this situation with a system recovery. Be very careful with this as there are options to erase all the data on your device.
20.3.1. To enter into the Recovery screen - Turn off the device and wait 10 seconds.
- Press and hold the volume + button while powering on the device.
- Keep the volume + pressed until the Recovery mode starts (white screen).
- To move from one Go to this web page to see the latest on-line version of this manual. Go to this web page to see the latest on-line version of this manual. Go to this web page to see the latest on-line version of this manual. Go to this web page to see the latest on-line version of this manual.option to another, use the volume buttons. To select an option, press the ON/OFF button. Go to this web page to see the latest on-line version of this manual.
20.3.2. Recovery mode options No: Cancels the system recovery.
Update firmware: Allows you to connect your device to a computer in order to copy the latest .AOS file (operating system) to your device and then install it.
Repair System
: Attempts to repair the file structure on the internal memory. This does not erase any data.
No: Return to main recovery screen.
Force Touchscreen Calibration
Select this, set your device down, start the calibration, and don't touch it. It will re-calibrate the screen. After the calibration is complete, select No to leave the recovery screen.
Check Disk: Check and repair the system partition if damaged.
Start USB MSC: Allows you to connect your device to a PC to access the internal memory.
Format System: Formats the internal memory. All data (music, photos, videos, etc.), applications and settings are erased.
HOPE IT HELPS AND GOD BLESS!!!
Archos 101 wont turn on
System recovery
- To move from one option to another, use the volume buttons. To select an option, press the ON/OFF button.
Repair System
Force Touchscreen Calibration:
Select this and then select no to leave the recovery screen. Upon restarting, the ARCHOS will immediately start the touch-screen calibration utility.
Format System: Formats the internal memory. All data (music, photos, videos, etc.), applications and settings are erased. "
copied from the Archos online manual
I can't download pdf files from emails on archos 101 8 gb tablet
make sure you have some PDF reader installed !! if it's already in your system then file format must be wrong or corrupted.
try for another files if problem presists then reply
Archos 101 internet tablet keeps going onto archos A101IT recovery when i turn it on i try to repair or format the devive and it just jeeps failing
every time i turn on my tablet it pop up archos A101IT Recovery.would u like to recover your system.no update firmwear.repair system.format system
I reformat my archos 101 tablet,now all the files are gone, when i turn it on alli see is archos a101it recovery ,can you please help. thanks
LOL, ok, Reformat does just that (Delete All Files). Unless you have them backed up someplace outside of the computer, they are history.
Format and Recovery deletes everything. Recovery will set your system back to the time you first purchased it. But your personal files will be gone.
System Restore on the other hand does not delete anything. It allows you to restore your system back to a particular date and time. Your documents, music, pictures, videos, data and programs will not be deleted. You might have to reinstall programs that you installed after the date and time you selected.
27helpful
3answers
Archos 101 internet tablet cant get out of demo mode
Try this:
Power your Archos 101 off by holding the Power Button for 10 seconds (this fully shuts it down).
While holding the Volume + button power it back up (tap power button to start up, hold volume until the tablet enters recovery mode, you'll see a series of choices instead of the demo mode).
Choose the Format System option.
When this process is complete make sure not to select Demo Mode as Android boots and the Archos 101 gets up and running.
1helpful
How do I transfer my sermons from my laptop to my Archos 101?
2 ways:
1. Copy sermon files from laptop to USB drive, then mount USB drive to Archos, go to files, external drive, copy files to ARCHOS from USB drive.
2. Connect laptop to Archos with USB cable & copy or drag files from laptop to Archos
Note: You will then need a reader / Office Suite/ or other app to view the sermon files. I assume the files are .doc files. Excellent app for this is Docs to Go.
Top Archos Tablets & eReaders Experts
SmartAviator
SmartAviator
Grand Canyon Tech
Grand Canyon Tech
Mike Cairns
Mike Cairns
Are you an Archos Tablet and eReader Expert? Answer questions, earn points and help others
