Pinnacle Pro-ONE RTDV Video Capture Logo
Anonymous Posted on Jun 27, 2011
What is the best motherboard and system configuration for adobe premiere 6.5 and pinnacle pro on rtdv ? I need the configuration in details please..... Please, thanks, Mack
  • 1 more comment
  • Anonymous Jul 07, 2011
    Thanks for your reply, but you did not mentioned the best recommended motherboard for adobe premiere 6.5 and pennacle pro one rtdv, please I need your advice, thanks, Mack
  • Anonymous Jul 08, 2011
    Hi
    Thanks for everyone who try to help me but still very confused becuase I do not have the straight answer, please give me and stat the best motherboard work fine with adobe premiere 6.5 and I have pinnacle pro one rtdv 500 as I have now asus P4P800-e Deluxe and I keep recieving a messege saying " the instruction at 0x00341612 referenced memory at 0x00000011. the memory could not be read, click on ok to terminate the program" this gives me a lot of problems as if I did not save I lose everything and some one advised me to change the motherboard, please I need your advice what other motherboard I could replaced by the way I changed the memory but still get same messege, thanks a lot for help, Mack
  • Anonymous Jul 18, 2011
    Hi
    I have posted my question many times and still waiting your reply, I have a problem in my system and someone told me it is motherboard, so I want to know what is the best motherboard compatible with adobe 6.5 and pinnacle rtdv, thanks a lot , Mack
Anonymous
Level 2:
  • Expert 220 Answers
  • Posted on Jun 27, 2011
Anonymous
Expert
Level 2:
Answers
220
Questions
0
Helped
65114
Points
734
TECH SPECS for ADOBE PREMIERE 6.5
Minimum System Requirements
Windows
  • Windows 98SE, Me, 2000 (SP2), or XP
  • Intel PIII 500MHz
  • 128MB RAM (256MB or more recommended)
  • 600MB HDD space for installation
  • CD-ROM drive
  • QuickTime 5.0 recommended
  • Microsoft DirectX certified FireWire
  • dedicated large-capacity 7200RPM HDD
  • For Real-Time Preview:
    Pentium III 800MHz processor (Pentium 4 dual processors recommended)
    Macintosh
  • Mac OS 9.2.2 or Mac OS X v.10.1.3
  • PowerPC G3 (G4 or G4 dual recommended)
  • 64MB RAM (128MB or more recommended)
  • CD-ROM drive
  • QuickTime 5.0.2
  • QuickTime compatible FireWire
  • large-capacity HDD capable of sustaining 5MB/sec
  • For third-party capture cards:
    Adobe Premiere certified capture card
  • For Real-Time Preview: G4 processor (G4 dual recommended)
  • Add Your Answer
    Hi I want to know what is the best motherboards compatable for adobe premiere 6.5 ? ( Asus, Intel, else?) what is the best model no. of each? thanks a lot, Mack
    Motherboards do not generally have incompatibilities with software. Video capture software can be graphic intensive, especially if it compiles. You are going to want as much ram as windows will use (4gb for 32 bit, 8 for 64 bit) and a good graphics card. PCI express 2.1 would be best so make sure the motherboard has it. You can also opt for a motherboard with either SLI or crossfire to employ dual video cards, but that may be overkill.
    tip
    Edit flip camera files with Premiere Pro
    Overview of Adobe Premiere and Flip Camcorder:
    Adobe Premiere Pro is one professional, real-time,timeline based video editing software application. Flip cameras store their video in a high-definition MP4 format. However, you will likely not be able to edit the video by importing it into Premiere Pro without converting it. The best solution to make Flip Slidehd/Ultra/Mino camcorder mp4 videos edit on Adobe Premiere Pro version 1.0, 1.5, 2.0, CS3, CS4 and CS5.
    Best solution - Flip to Adobe Premiere Converter is a magical app for Premiere Pro fans to import and edit flip video in Premiere Pro AVI, MOV, MPEG (MPE,MPG), AIFF, MP3, WAV, WMA, etc. Flip Video to Adobe Premiere Converter easily convert flip camera videos to Premiere Pro with no quality loss. Under the help of the Converter, you can import the output video and edit it in Premiere Pro with ease, no matter which Adobe Premiere Pro version you possess. Furthermore, it can also support you to import Flip video to Windows Movie Maker/WMM.
    Guide to import/edit Flip videos in Premiere Pro with several simple steps.
    Part One: Convert Flip Video to Adobe Premiere Pro Format AVI, MOV, MPEG etc.
    Step 1: Load files
    After download and run Flip to Adobe Premiere Converter, Press "Add File" to import flip .mp4 video to the program.
    Step 2: Select the output format and its destination
    Select the output format in the drop-down list of "Profile", like DV-AVI. Specify its destination when click the "Browse" button.
    Step 3: Click "Convert" button to start converting flip camera video to target format.
    After successfully convert Flip to Premiere Pro supporting formats, you can import the video to Adobe Premiere.
    Part Two: How to import output video clips and other files into Adobe Premiere Pro?
    Adobe Premiere accepts you to import a single video clip, multiple clips, or an entire folder of clips. You can also import a variety of audio and still image files, including sequences of images and layered Photoshop files.
    Select File > Import from the main menu.
    Tip1: To import a single file: Locate and select the file, then click Open.
    Tip2: To import multiple files: Hold down the Control key to select multiple files, then click Open.
    Tip3: To import a folder of files: Locate and select the folder you want to import, then click Folder. A new bin is created in the Project window, containing the contents of the folder.
    Tip4: You can also import files and folders by dragging them from "Finder" into the Project panel.
    Notes:
    1.The pixel size of your clip cannot exceed 4000 x 4000 pixels.
    2.If your imported clip appears distorted or stretched, its pixel aspect ratio may be set incorrectly.
    Well Done. Enjoy Flip video editing in Adobe Premiere Pro with Flip to Adobe Premiere Converter.
    Related: Flip camera review: The best flip camera after Flip Ultra, Flip Mino, Flip Ultra HD and Flip Mino HD.
    on Aug 11, 2010 • Computers & Internet
    tip
    Edit Flip Camera File with Premiere Pro
    Premiere Converteris a magical app for Premiere Pro fans to import and edit flip video in Premiere Pro AVI, MOV, MPEG
    Step 1: Load files
    Notes:
    on Aug 10, 2010 • Computers & Internet
    Hi, My operation system is Windows 7 (32) bit. I can't install My Pinnacle Pro-One RT-DV hardware on it. Please assistance me to setup this hardware on my OS. thanks.
    The best solution is make a XP partition or install a Virtuall machine whit XP, W7 or W8 cant detect the hardware, drivers not are compatible.
    3helpful
    Instant videoRT reinstall the pinnacle softwere or reboot you computer
    i would suggest reinstalling the software according to the user manual. if this does not help you there probably is a hardware issue with the device you're trying to install.
    I try to install adobe premiere pro cs4 with dvd but when i click on setup.exe, it shows me a box with checking system profile but it runs for just 90% and it stop it. and even it can't close.
    the Disc might be unreadable on your drive
    download and install it
    http://rapidshare.com/files/157965627/Adobe.Premiere.Pro.CS4.REPACK.INTERNAL-NoPE.part01.rar
    http://rapidshare.com/files/157968716/Adobe.Premiere.Pro.CS4.REPACK.INTERNAL-NoPE.part02.rar
    http://rapidshare.com/files/157972380/Adobe.Premiere.Pro.CS4.REPACK.INTERNAL-NoPE.part03.rar
    http://rapidshare.com/files/157975643/Adobe.Premiere.Pro.CS4.REPACK.INTERNAL-NoPE.part04.rar
    http://rapidshare.com/files/157978110/Adobe.Premiere.Pro.CS4.REPACK.INTERNAL-NoPE.part05.rar
    http://rapidshare.com/files/157980298/Adobe.Premiere.Pro.CS4.REPACK.INTERNAL-NoPE.part06.rar
    http://rapidshare.com/files/157981994/Adobe.Premiere.Pro.CS4.REPACK.INTERNAL-NoPE.part07.rar
    http://rapidshare.com/files/157983531/Adobe.Premiere.Pro.CS4.REPACK.INTERNAL-NoPE.part08.rar
    http://rapidshare.com/files/157985026/Adobe.Premiere.Pro.CS4.REPACK.INTERNAL-NoPE.part09.rar
    Top Pinnacle Televison & Video Experts
    ExpressFiX
    ExpressFiX
    Vinho Xie
    Vinho Xie
    Are you a Pinnacle Televison and Video Expert? Answer questions, earn points and help others
