SOURCE: cant login to y.m but can connect to internet,
I would like to help you with your issue. but we have to check the following first
http://webmessenger.yahoo.com/ try log into the Web Messenger
> Step 1: Test Your Internet Connection
> Step 2: Verify Your Yahoo! ID and Password
Open Internet explorer and www.mail.yahoo.com
Check by sign in to you account
> Step 3: Test Your Access to Secure Pages
Make sure that you can access secure pages from Internet Explorer
Try to sign in to Yahoo! by going to the Yahoo! sign in page and enter
the same Yahoo! ID and password you were using before.
> Step 4: Verify Credentials
Verify that the same Yahoo! ID and password you used before in the last
step also works in the online version of Messenger, Yahoo! Messenger
for the Web:
enter the same Yahoo! ID and password you were using before.
> Step 5: Check Connection Settings
Click the Messenger menu and select Connection Preferences.
Click Connect directly to the Internet, and then click OK.
Check by Changing the connection type to a connection via a proxy server:
Click Connect via a proxy server, then under this option, select HTTP proxy, and then click OK.
Last is Uninstall all the Yahoo Tool Bars and Yahoo applications , Yahoo Messenger, and Yahoo Updates from Program list i.e Control panel - Add/Rem Programs ..
And reinstall the Yahoo Messenger again -
Hoping this article will be helpful for you
SOURCE: help me to solve my problem
Test your account with web messenger by logging in here:
If this fails, it means that there is a problem with your userid, password or account. Contact Yahoo for assistance.
If this works, then proceed to the next step.
Ensure you have a good stable internet connection.
Uninstall Yahoo Messenger and everything associated with your messenger.
Download the latest version from messenger.yahoo.com.
Try to log in again.
This should work and fix your problem.
Let me know how it works out and don't forget to give me a good rating as well as your vote.
SOURCE: hi cannot able to connect
Please uninstall the messenger, download and install latest yahoo messenger and try. Still if you are failed, try login with http://webmessenger.yahoo.com, let us know the result.
Thanks for joining us.
Have a good day.
SOURCE: Checking virtual IP servers... [VIP Raw]
por favor solucionen mi problema no me deja abrir mi msn dice que mi cuenta a sido bloqueada y que tengo que desbloquearla , ayudame por favor desbloqueela en codigo de desbloqueo es 81003003 ese codigo me dan para entrar ahi
Looks like the packets are being blocked by a firewall.
Your entire message did not fit and was not displayed. Can you please describe the problem?
Thanks
