Hitachi RAS-09UH Air Conditioner Logo
Posted on Jul 21, 2017
I've bought 1.5 Ton Hitachi Ace Follow Me Split Air Conditioner (RAU018EQD). I'm facing problem with my Remote Control unit. The moment you insert the batteries in it, the display lights gets ON and doesn't go off. The unit does not respond even if you press any button on it and Nothing is visible on it as well. I pressed the Reset button on the Remote as well, but of no use. Please advise and help me.
5 Related Answers
christian nielsen
  • 358 Answers
  • Posted on Apr 04, 2009
SOURCE: Hitachi RAS 5142CHA Won't operate
Check the fuse on the control board inside the head unit,if its ok you need to replace the contrl board
Anonymous
  • Posted on Feb 08, 2010
SOURCE: BROKEN/MISSING HITACHI AIRCONDITIONER REMOTE CONTROL rar-2p2
abhay .hi their is a problem in my remote
Anonymous
  • Posted on Mar 23, 2010
SOURCE: I NEED A USER MANUAL FOR A HITACHI SPLIT SYSTEM
http://www.hitachiaircon.com/argws/listDOCS.do?pageName=Technical+Manuals&range_id=1&page=PAGE&button=Submit&categoryID=-1&action=getListTechManuals&d-49653-p=14
Anonymous
  • 1035 Answers
  • Posted on Sep 02, 2010
SOURCE: We have a Hitachi wall
Hi. Here's the link where you can purchase a remote control. Please click here.
hvac1960
R Subramaniyam Iyer
  • 2133 Answers
  • Posted on Dec 16, 2010
SOURCE: Hitachi DC Inverter (heater/air conditioner) -
Down load free or cost basis your required manuals:
SERVICEMANUALS @ COST www.mauritron.com
Manuals at free download: homeappliance.manualsonline.com/manuals/.../lg_air_conditioner_product_list.html
H4 error code is shown on AC display what can i do to slove this problem
Full list of Gree Air Conditioner Mini Split Units Fault Codes. When error codes appear on the Gree air conditioner indoor display, this tells the user there is an issue with the Gree AC unit. The error code displayed will inform you of the issue or problem that is occurring with the air conditioner. Knowing what the error code means and its definition will help you to understand and troubleshoot the exact Gree air conditioner part that needs to be fixed, cleaned, repaired, or replaced. You can then clean, fix, or replace the Gree part yourself and save money. See below for all error codes that can occur on Gree Mini Split AC's.
Gree Mini Split Air Conditioner Error Codes - How To Fix
Gree Viero AC Mini Split PDF Owners and Troubleshooting Manual
GREE DUCTLESS AIR CONDITIONING & HEATING SYSTEM INSTALLATION MANUAL
Gree Mini Split Air Conditioner Part Names and Locations
INDOOR AND OUTDOOR UNIT
The Gree Air Conditioning Vireo System has onboard error code diagnostics. The outdoor unit will provide status indicators and the indoor wall unit and remote control will display error codes. The following is a summary of the codes with explanations...
GREE AC DIAGNOSTIC ERROR CODES
Gree Vireo Mini Split Air Conditioner Error Code F0
Refrigerant Leakage Protection
1) Refrigerant leak(s).
2) Indoor coil temperature sensor not calibrated.
3) Refrigerant flow is restricted (ex. valve, exv, debris)
Outdoor Unit Red Light Indicator - 9 flashes and 1 sec Off
Gree Vireo Mini Split Air Conditioner Error Code E1
System High Pressure
1) Over charged with refrigerant.
2) Blocked or dirty outdoor coil.
3) Extreme outdoor ambient conditions
Gree Vireo Mini Split Air Conditioner Error Code E2
Indoor Anti-Freeze Protection
1) Low return airflow.
2) Indoor fan speed is too low.
3) Indoor coil is blocked or dirty.
Outdoor Unit Yellow Light Indicator - 3 flashes and 1 sec Off
Gree Vireo Mini Split Air Conditioner Error Code E4
Compressor High Discharge Temperature Protection
Please refer to the malfunction analysis (discharge temperature, overload) in service manual.
Outdoor Unit Yellow Light Indicator - 7 flashes and 1 sec Off
Gree Vireo Mini Split Air Conditioner Error Code E5
Overcurrent Protection
1) Supply voltage is unstable.
2) Supply voltage is too low and system load is too high.
Outdoor Unit Yellow Light Indicator - 5 flashes and 1 sec Off
Gree Vireo Mini Split Air Conditioner Error Code E6
Communication Malfunction
1) Communication cable is wired incorrectly between indoor and outdoor units.
2) Indoor or Outdoor control board malfunction.
Outdoor Unit Yellow Light Indicator - Continuous On
Gree Vireo Mini Split Air Conditioner Error Code E8
High Temperature Resistant Protection
1) Incorrect refrigerant charge level.
2) Refrigerant metering device malfunction.
3) Compressor malfunction.
Outdoor Unit Yellow Light Indicator - 6 flashes and 1 sec Off
Gree Vireo Mini Split Air Conditioner Error Code EE
EEPROM Memory Malfunction
Control board malfunction.
Outdoor Unit Yellow Light Indicator - 11 flashes and 1 sec Off
Gree Vireo Mini Split Air Conditioner Error Code C5
System Configuration Malfunction
1) No jumper cap inserted on the control board.
2) Incorrect or damaged jumper cap on control board.
3) Indoor and outdoor units are not compatible.
Gree Vireo Mini Split Air Conditioner Error Code Fo
Pump Down or Gathering Refrigerant Status
Optional Service Mode
Outdoor Unit Yellow Light Indicator - 17 flashes and 1 sec Off
NOTE: All of the Gree Air Conditioner Model Numbers below are applicable for the error codes on this page...
Gree AC Vireo Models: VIR09HP115V1A, VIR12HP115V1A, VIR09HP230V1A, VIR12HP230V1A, VIR18HP230V1A, VIR24HP230V1A, VIR30HP230V1A, and VIR36HP230V1A.
Gree Mini Split Air Conditioner Error Code Charts
Gree Mini Split AC Remote Control Button Names
Gree Mini Split AC Remote Control Icons Display Screen
Gree Mini Split Air Conditioner Air Filter Cleaning Procedure
Need help with error codes on your Gree AC? Please leave a question below and we will be happy to help.
1helpful
WHAT IS REFRIGERANT SUCTION PRESSURE OF MY 1 TON SPLIT AC?
R22= 70-80psig
R410a=120-130psig
Depending on many variables such as blower speed, coils clean, indoor/outdoor temps.
69helpful
4answers
LED LIGHT BLINKING OF HITACHI SPLIT AIR CONDITIONER
Did you figure out why the ac wasn't responding to the remote? I am having the same problem. I just cleaned out the filters but it's still not responding to the remote. I have already tried reset button in the remote, which didn't help. I am pretty sure that the remote is not out of battery.
Have a 18,000 btu amcoraire duo split unit and lost remote control how can you adjust temp without the remote
You can't adjust anything without the remote,
go to ebay.com search Amcoraire remote control, you will find what you need.
I have a Hitachi ras-35ca1 unit and the remote control stopped working. I can manually turn the unit on but cannot change any settings. I brought a Digitech universal remote to control the unit but I...
Hello Rachael8104,
I unserstand that you are having a problem with you Hitachi air conditioner split nonduct unit. I have located a web page for you to contact the nearest local dealer to your area. Follow the follow url to the webpage and pick the closet dealer and see if they can not order you a replacement remote for your unit http://www.hitachiaircon.com.au/contact-us.aspx
Thank you for choosing FixYa.com
Justin
3answers
WHICH IS BEST A/C NOW
Check out this site. you will get an idea about the types of AC so that you can buy it according to your choice.
http://www.hellogiri.com/home-air-conditioner-split-ac-window-ac-price-details-in-india-best-cost/
thanks for rating Good luck
4helpful
3answers
Top Hitachi Heating & Cooling Experts
jws1013
john h
Are you a Hitachi Heating and Cooling Expert? Answer questions, earn points and help others
