Forgetting Windows password is common thing nowadays, there are several practical tips for you. Top 1: Windows Password Key Top 2 : Windows 7 password reset disk Top 3: Repairing Windows 7 System
The first solution is using Windows Password Key and it consists of three parts in order to Windows 7 password recovery.
1. First you need to download the program in any available Computers and install it. Prepare a blank CD/DVD dive, or just a 2GB USB Flash Drive is OK. Run the program and then burn the ISO image file to CD/DVD or USB Flash drive. It is easy for you to do this and just takes a few minutes.
2. Turn to your locked PC and then insert the newly created CD or USB Flash drive. To make your computer to boot from CD or USB you need to set the BIOS. Restart your Computer and then press F2 to your bios and then select boot tap change the hard disk drives to the first. Usually there is no need to set bios if you don't change your bios setting before. If you have any questions, watch this.
3. Restart your computer and you will find Windows Password key isnitializing, follow the instruction to recover windows 7 password, it is not complicated, anyone can do it well.
This program is 100% recovery rate, you can log into your computer in less five minutes if you follow this tip.
Like other system, Windows 7 allow you create a password reset disk to reset your Win7 forgotten password. But you need to create a password reset disk before losing windows 7 password. Actually, when you add a password to your account, the first thing you should do is creating a password reset disk. If you have create a password reset disk before and now you have forgotten your Windows administrator password, do as follows.
1. Insert your password reset disk to the computer, click Reset Password.
If you don't have a Windows 7 password reset disk, you can boot into the Advanced Boot Options screen and then repair your computer as follows.
Note: II have forgotten my administrator password and I - windows%207%20password%206.jpgSystem Restore had to be enabled and you should create a restore point before you losing windows 7 administrator password.
I have forgotten my administrator password and I - windows%207%20password%207.jpgs booting from CD or DVD.
2. Click Startup Repair and you'll see a restore point that you want to use.
3. When finish, restart your computer and see if you can log in.
I alwys heard some people say that he lost his password, and he feel confuse. Here I summarize some ways to reset windows password in my blog, may be you can read that. http://blog.resetwindowspassword.com/ Good luck!
I know a good way to reset the password and it needn't reinstall Windows OS and not lost a little data. A reset windows password tool is called Windows Password Seeker. It can reset almost all Windows passwords in seconds. It is Windows Password Seeker. It also support windows 7 password reset. That's worth trying. http://www.passwordseeker.com
SMARTKEY Password Recovery Bundle is a must-have toolkit to recover/remove/reset passwords for Windows, Excel, Word, Access, PowerPoint, Outlook, Outlook Express, PDF, RAR/WinRAR, ZIP/WinZIP, MSN, AOL, Google Talk, Paltalk, Trillian, Miranda, Opera, Firefox and IE Browser, etc. Over 21 types of passwords can be Recovered instantly. Until now, these password recovery tools are the fastest on the market, the easiest to use and the least expensive..
http://www.recoverlostpassword.com/products/passwordrecovery.html
Lost Windows 7 password ? you can go into safe mode (F8 when booting up) to recover windows password when you forgot user account password,but if you forgot administrator password ,there is no way to change administrator password when you forgot it,you must use software to recover administrator password .my favorite is Windows password recovery tool .
Here is a simple way to access
Windows XP with Administrator rights and privileges if you have password
protected your User account on your Windows XP system and can't
remember the password(s) to login. Whenever Windows XP is installed on a
system, it creates a default account called "Administrator" and by
default this account is not password protected. Therefore, if you bought
a brand name computer (such as Dell, HP, Compaq or Sony)or you have
installed Windows XP yourself. You should be able to login to the
computer through the unprotected Administrator account.
Method One
Setting new password
Method 2
Method 3
Method 4
TRY command prompt about password reset trick
Type: net user You get a list of accounts Type: net user Administrator * Type: net user (any account on that list) *
Now, try to log on as 'Administrator' with your new password.
Method 5
Reset Windows Password with Windows Password Breaker.
Method 6
Reset password with RESET DISK if you made before.
Windows XP and further versions also provide another method to
recover forgotten password by using "Reset Disk". If you created a
Password Reset Disk in past, you can use that disk to reset the
password. To know more about it, please visit following links: http://support.microsoft.com/kb/305478
Method 7
Remove the password with Windows Login Recovery.
If my solution make you happy then give the four Thumb
SMARTKEY Password Recovery Bundle is a must-have toolkit to recover/remove/reset passwords for Windows, Excel, Word, Access, PowerPoint, Outlook, Outlook Express, PDF, RAR/WinRAR, ZIP/WinZIP, MSN, AOL, Google Talk, Paltalk, Trillian, Miranda, Opera, Firefox and IE Browser, etc. Over 21 types of passwords can be Recovered instantly. Until now, these password recovery tools are the fastest on the market, the easiest to use and the least expensive..http://www.recoverlostpassword.com/produ...
The account that you c?n use, a admin ?
