Hi Lou
We would recommend you contact Phil & Teds directly for assistance
STROLLERS BABY PRODUCTS FOR YOUR PARENTING DAY
SOURCE: attaching toddler seat
HELLO ARE U SURE U GOT THE WRONG ELBOW JOINTS BECAUSE I THOUGH THAT WHEN I GOT MY ELBOW JOINTS BECAUSE THE SEAT WAS BIGGER THEN THE FRONT OF THE BUGGY BUT ALL I DID WAS PUSH EACH SIDE OF THAT SEAT TOGETHER ITS A BIT HARD TO PUT ALL TOGETHER. I THINK ALL THE ELBOW JOINTS ARE THE SAME (NOT 100% SURE)
SOURCE: Can I buy a removable Bumper Bar for my Bertini Shuttle pram??
http://www.bertini.com.au/pages/contact.php
There is their web address. Contact them.
please rate my answer as a fixya!
SOURCE: does toddler seat for emmaljunga fit all
No, the older toddler seats will not fit the newer model strollers. You will need to check the toddler seat and see how it attaches to the pram, there are two different styles.
SOURCE: Jane powertwin carrycot/car seat
With the Powertwin, you can only use the Rebel carseat. With the newer model 'Pro Generation' Powertwin, you can use the Strata carseat also.
It sounds like you have a non-pro version, so you should only use the Rebel Non-Pro carseat. You would normally get the adapters with the Powertwin (one set is grey and one set is black, you get both with the pram) but if you don't have these, you can contact www.johstonprams.co.uk who will sell these to you.
I hope this helps.
SOURCE: emmaljunga toddler seat
You can not get a manual any more as they are not made. They are releasing a new seat in Feb 2010. This works in an identical way so I have been told. I have the old seat. It is easy to understand how it is fixed, but I would have a strong man to help, it can be tough.
Step 1 : locate bumper bar and with an alan key undo the two black clips either side that hold it together. Remove bumper bar from pram, Keep the two clips on the pram with the opening facing up.
Step 2 : With your toddler seat you should have another two of these black clips, place these two on the pram in the same way, but as far forward as they will go.
Step 3 : On your seat either side of the black knob that reclines the seat you will find two holes, simply place the seat lined up with the clips, put the screws with the clips threw the clips and the holes in the seat place, put the other side of the screw on and tighten. Thats it seat on.
