Sony FD Trinitron WEGA XBRKV-40XBR800 40" TV Logo
Posted on Aug 23, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sony Flat Screen XBR
Hi, my television's picture goes in and out.. and when it does, the stand by light (red) flashes on and off. I am still able to hear sound, but there is no picture every thirty seconds or so for about 30 seconds, if not longer. Is this something I can fix myself?
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 236 Answers
  • Posted on Aug 23, 2008
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
236
Questions
Helped
45017
Points
593
Your lamp may be going bad.
replace the lamp by sending it to sony (if under warranty) or order a new lamp from sonystyle.com .
the location of the lamp should be in the manual.
Sony XBR-70X850B turns on, displays picture, then shuts off, and flashes LED lights 4 times.
HI
in this case most common problem is ld board or panel if the set red light blink 4 times
When I turn on the power the screen will light up briefly then go off, then the standby light goes on (red) and flashes in four times flash intervals
4 blinks notifies the back light failure . could be the back light inverter board or faulty capacitor on power supply board.have added the image of back light inverter. Also added the picture of the power board. On the picture the capacitors marked with red should be replaced first. If shows the same complaint even after that then you have to change the back light inverter board.
Power supply
Back light inverter board
25849195-rpi3jfilu1hke134nfog5c4e-2-9.jpg www.electro-medical.blogspot.com
Green standby lamp flashes but power light does not come on and there is no picture
Here you go:
http://www.highdefforum.com/rear-projection-tvs/109533-flashing-green-standby-lite-then-flashing-red-lamp-light-sony-wega-50-xbr.html
16helpful
The picture comes for 2 secs on the screen and immediately goes to stand by and red LED Sony bravia standby mode blinks 8 times
the picture comes for 2 secs on the screen and immediately goes to stand by and red LED Sony bravia standby mode blinks 8 times
My sony xbr 60 picture turns off and on
No solution for you...but I have the same problem. I also had the green blob problem which sony fixed earlier this year. It happens on an intermittent basis. Screen goes off, standby light blinks green, then comes back on. Its off for maybe 1-2 min.
4helpful
Sony Vega KDF-E5OA10,picture will not come on, tv goes off.
There is a real good chance that the lamp fan is not turning. If you look with a flashlight in the vent on the left side looking at the rear of the set and have someone turn on the unit, see if it spins. if it doesnt, the protect circuit in the tv will not let the set turn on. Replacing the fan will cure the proplem if it is not turning.
Hope this helps,
Skyassoc
Television switching itself off with red light flashing.
Had same problem on a 50inch wega tv. It needed lamp replaced,not hard to replace about $180.00
from Sony.
3helpful
4answers
Tv tunrns on then goes to stand by flashes 4 times & repeats
turn tv on picture comes up 2to3 seconds later tv blacks out then stand by red light flashes 4 times in a row repeatedly..can not turn on or off when stand by light starts flashing but before tv blacks out you can turn tv on and off repeatedly and picture and sound work.You have to unplug power cord for 30 seconds after stand by light comes on to get tv to turn on.
SONY 36 XBR SOUND BUT NO PICTURE
posible solution is adjust the screen to low.also check the trimer if it is working.check the resistor in the heater line...weng
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
