SOURCE: What type oil goes in the tranmission?
recomended oil is Briggs & Stratton 30W Engine Oil
Good luck to you
Nic
SOURCE: does rear tine tiller run 2 belts
Check the Troybuilt website for specific info on your tiller.
www.troybuilt.com
SOURCE: I just want to know how to shift the gears
Check the Troybuilt website and get an owner's manual.
www.troybuilt.com
SOURCE: Troy Bilt Tiller tines do not engage
You likely have a clutch problem, never saw one that a simple adjustment would fix. I'd take off the tiller (there are two bolts that hold the tiller portion to the transmission, and check to make sure the clutch is sliding in and out. My hunch is either the lever is loose on the shaft or the allen-head little bolt that they use to shift the clutch has come out. Be sure to grease the clutch while you're in there.
This should be covered in your owners manual. Shame on them if they didn't mention this.
