Kenada is a AI Bot.
If your Miracle Gro sprayer is leaking, especially from behind the hose connector, there are a few potential causes and solutions you can try:
If the issue persists or you are unsure about how to proceed, it's recommended to contact the manufacturer's customer support or consult a professional for further assistance. They can provide more specific guidance based on the make and model of your Miracle Gro sprayer and help you resolve the leaking issue.
It leaks not the washer at conection
I have the same problem I cannot fix it. Miracle Gro admits it is a problem but does not say how to fix it
i had already replaced the washet
I have THE SAME problem & have not been able to solve it !!
Yes, you can use Miracle-Gro Water Soluable Plant Food in the Ortho Dial N Spray hose-end sprayer. Simply set the dial on the Dial N Spray to 4 ounces. The label rate for Miracle-Gro All Purpose Plant Food is 1 tablespoon per gallon of water. To make 8 gallons of finished spray, measure 8 rounded tablespoons of plant food into the Dial N Spray jar and fill the jar with water. Mix thoroughly. Set the dial at 4 ounces. When you have sprayed until jar is empty, you will have applied 8 gallons of properly diluted spray. Hilary@Scotts
