Watches Logo
Posted on Jun 26, 2011
How to set day and date on a Benrus quartz watch model # BN529? Has one stem with two pull out positions. The first position only changes date going only in direction.
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 4 Answers
  • Posted on Jun 26, 2011
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
Questions
Helped
665
Points
8
Typically, you need to run the time around until the right day is up and the right time is set to am or pm. Then turn in the other stem position until the correct date shows up.
I need to change the date on my watch and don't have the instruction manual. Thanks!
mcdevito75 here, Sounds like you have the time set, but the date is a fifferent matter, Here"s what to do, the stem (winder) of your watch has 2 positions, slip a fingernail just under the stem, and gently lift the stem to it;'s first position, this position allows you to change the date without so many cycles of the entire watch, it"s a little tricky but you"ll get used to it. Once you get this first position set the date to 1 day before the date you want, now pull the stem out to set the time of day, go thru 1, 24 hour cycle to set the date you want and time of day. The date is now set and will change on time, approx. Mid nite. Hope this helps.
Aug 03, 2010 • Watches
tip
HOW TO SET DAY / DATE ON AN ANALOG (STEM) WATCH
mcdevito75 here, Over Forty (40) years ago, watch manufactures added, to some of their ANALOG (wind up) and almost all of their DIGITAL (button display) watches the FEATURE of the, MONTH or DAY of the WEEK and the DATE, not only was the time of day available but also the DATE which you no longer had to go searching for, it was readily available on your wrist. The PROBLEM came with SETTING the CORRECT MONTH or DAY of the week and the DATE as some MONTHS HAD 31 DAYS rather than 30 DAYS, this meant you had to CYCLE your watch at least 62 times to get to the CORRECT DATE and mant times, when you finally did reach the CORRECT DATE, the day of the week was off, meaning more CYCLES thru the 24 hours.-------- HERE is the EASY way to SET the MONTH or DAY / DATE on your QUARTZ / MECHANICAL (STEM) watch without haveing to go thru the 24 hour cycle so many, many times. Not only is this, WEAR on your fingers, you can also damage your watch with some many cycles of the 24 hours to SET the correct MONTH or DAY / DATE. ------ HERE ARE THE BASICS,---------- Your ANALOG or STEM watch either QUARTZ or MECHANICAL should have a TWO (2) position STEM we are only familiar with the ONE (1) position we use to set the TIME, there should be TWO (2) positions to the STEM. First pull out the STEM to adjust the MONTH or DAY depending on your watches display, if your watch DISPLAYs the DAY of the week, set the DAY to one (1) DAY before the DAY you want, don"t worry about the DATE (number) yet. Once you have the MONTH or DAY set, push the STEM back into the watch, NOW with a finger nail just under the STEM (usually from the back of the stem as there is more room) gently lift the STEM to it"s first position, It may take some practice so be patient, once the STEM is in it"s first position you should be able to turn the STEM to adjust the DATE (number), if so Adust the DATE (number) to ONE (1) DATE before the DATE you want, This way your watch will be adjusted to change the DAY / DATE at the correct time. Once you have the DATE (number) adjusted to ONE (1) DATE before the DATE you want, push the STEM back into the watch, NOW pull the STEM out to adjust the time, go thru the 24 hour cycle to adjust to the correct DAY DATE (number) and time of day.------------ Your QUARTZ or MECHANICAL (stem) watch is now adjusted to the correct DAY / DATE and will change at the correct hour which is generally 12--1 AM.
on Jul 20, 2010 • Watches
tip
on Jul 09, 2010 • Watches
Westclox model LTX271 instructions for setting day
mcdevito75 here, The stem on your westclox has 2 positions, First pull the stem out to set the time of day, keep cycleing the watch until you come to 1 day before the day you want. NOW! push the stem back in. NOW! slip a finger nail just under the crown and gently, gently kift the crown to it"s first position, it may take a little practice so be patient, once in it's first position you can change the DATE easily, change the DATE to 1 DATE before the DA you want, push the syem back in and pull the stem back out and set the day/date and time of day. Your watch is set and will change on time a little past mid nite.
7helpful
How to set an Armitron watch. Can't set the days correctly.
mcdevito75 here, The stem has 2 positions, Carefully slip a fingernail under the stem and lift, it may take a few trys to get used to it, in this first position you should be able to set the DATE very easily and Maybe the DAY of the wwek also, turn the stem 1 way to change the DATE and the other way For the DAY of the week., Let"s figure you can only set the DATE in this first position, First thig to do is set the DAY of the week, go thru the watches 24 hour cycle and set the DAY to 1 DAY before the DAY you need, now in that first position of the stem, set the DATE to 1 DATE before the DATE you need, now in the 2nd position we all know pull the stem out to set the time of day, go thru the 24 hour cycle to bring up the DAY of the week and DATE you need. Now your watch is set and will change on tome at around mid-nite.
Jul 21, 2010 • Watches
4helpful
I just purchased a vintage Seiko automatic DX and I can't figure out how to change the date and day that appears on the watch.
mcdevfito75 here"s how to change the day and date on your vintage Seiko watch, Pull the stem out to the set position and simply turn the stem (winder) every second time around to the 1--2 3 O"oClock position the day will chage, once you get the day push in the stem in all the way, NOW with your fingernail just under the stem (winder) gently lift the stem up to it"s first notch or position, with the stem at this first notch or position, you can turn the stem and the hands won"t move but the date(number) will change, simply go to the correct number / date and your done, push the stem back in a your ready to go.
3helpful
Adjusting day/date on a self winding Seiko, 7S2GB
mcdevito75 here, Your stem has 1 positions to set the date easily without haveing to cycle the watch 60 times. First pull the stem out to set the day, set the day 1 day before the day you want, next, push the crown back in, NOW! Slip a finger nail just under the crown from the back as there is more room, it may take some practice so be patiernt and gently, gently lift the crown to it"s first position, once in it"s first position turn the stem and see the DATE change, set the DATE to 1 DATE before the DATE you want, NOW pull the stem out to set the day date and time of day. Your watch is set and the day date will change on time, a little past mid nite.
5helpful
Changing the DAY on this analog watch.
On some analog Timex watches with a day/date window there are only two "pull-out" positions on the stem, one for changing the date and one for the time. To change the day you need to pull the stem all the way out and crank the hands through 24 hour periods until you get the day correct. Be sure that you have the correct AM/PM setting (if you are setting the watch after noon you need to advance the hands another 12 hours so that the day changes at midnight)
Sep 07, 2008 • Watches
1helpful
Operating instructions for a replica Rolex oyster perpetual cosmograph daytona watch
I need to know if this watch is an automatic or quartz (battery-operated) watch. For either watch, your crown screws in clockwise- which, by the way, is on the right hand side of your watch, and looks like a miniature doorknob. Unscrew it COUNTERCLOCKWISE, then, if your watch has a date on the dial (face of watch), your crown will pull out in two different positions. The first position is for your day/date. Forward will either do the day or date and backwards will do the other. DO NOT SET YOUR WATCH BETWEEN 10 O'CLOCK AND 2 O'CLOCK, because it can ruin your watch. The second position (pull out completely) is for setting the time. Go around until the day and date changes so you're sure that you're on a.m. or p.m. and then set accordingly. Push the stem all the way back in - this is your winding mode if you have an automatic. Wind 50 times before use, or else it won't run correctly. Now, push the stem back in (it's spring-loaded), and turn it counterclockwise to seat the tap, then clockwise until it's completely screwed in.
Apr 22, 2008 • Watches
8helpful
2answers
HOW TO CHANGE DATE
The Skagen watches have  two-step stem; fully pulled out will change the time and partially pulled out will change the date (only goes one way so try turning it counter-clockwise or clockwise - I forget which is correct).  It's easier to find the date length by extending it all the way and then go back toward the case.  It won't change the date if you run it through a 24-hour cycle - you have to do the half-way thing.  Hope this helps.
Top Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Watch Expert? Answer questions, earn points and help others
