Sounds like to me
its overheating
or the HDD is going SOUTH.
upgrade to SSD
what we do in a shop is run disk tests.
extensive, to see if the smart page is borked
see that example here.
see parameter 05 and C6 here, if wrong the HDD is DOOMED
i pro system (like servers) it send email to the tech telling ,him
Drive 126 failing (this param) and the pull it before dies.
the who internet runs like this. (predictive failures)
Hi Jamiekom.
Slow Running Computer Fix. Use MSCONFIG to improve computer's speed at startup. You can disable certain programs that auto-start at startup and spend less time waiting for your computer to fully boot. Simple tip to improve your computer's performance.
Why is computer so slow to startup?
My Windows computer boots up slow. A slow Microsoft Windows boot up can be caused by a number of different issues. The following document contains various suggestions and tips that can help improve the overall speed of your computer's startup.
Why does it take so long to boot up my computer?3. Upgrade your hardware. A new computer is naturally going to start up faster because it has faster hardware, and a clean operating system. ... As we said above, computer startup is slow because you're moving information from a slow hard drive to faster RAM
Computer running slow at startup Check out this Quick Tip
computer slow on start up Google Search
During the boot process, a blue bar with www.dell.com appears at the top of the screen.
If you do not press in time, let the computer finish starting, and then restart the computer again.
NOTICE: If you do not want to proceed with PC Restore, click Reboot in the following step.
The restore process takes approximately 6-10 minutes to complete.
The computer restarts. Because the computer is
restored to its original operating state, the screens that appear, such
as the End User License Agreement, are the same ones that appeared the
first time the computer was turned on.
The System Restore screen appears and the computer restarts.
After the computer restarts, click OK.
Thanks and have a good one.
Oliver
Step 1: Enter Safe Mode
a)
Start or re-start your computer.
b)
Before the Windows 7 loading screen appears, Press 'F8? to enter
Advanced Boot Options.
c)
Use arrows to choose 'Safe Mode' when you can see the Advanced Boot
Options screen.
d)
Press 'Enter' and wait for Windows 7 files to load.
e)
Log on with an administrator account when you can see the log on screen
Note: Well, when you are presented with the
Advanced Boot Options screen, there are 3 types of Safe Mode. They are the Safe
Mode, Safe Mode with Networking and Safe Mode with Command Prompt, and the 3
options are all available for you. Here above we take Safe Mode as an example,
but if you choose Safe Mode with Command Prompt, you'll need to input related
to command prompt to reset the password.
Step 2: Reset the forgotten Windows login
password in Windows 7
Now you could diagnose and solve some serious
computer problems in the safe mode and reset the forgotten Windows login
password in Windows 7 as follows:
1.
Click 'Start' button, input 'lusrmgr.msc' into the Search box and press
'Enter'.
2.
In the 'Local Users and Groups screen', click 'Users'.
3.
Right-click the account that you need to reset the password for, and
then click 'Set Password'.
4.
Type and confirm the new password, click 'OK'. (You can go to 'Local
Users and Groups' screen by right-clicking 'Computer' to select 'Manage' on
desktop.)
Step 3: Log on your password protected PC again with the new password since you have successfully performed Windows password reset for Windows 7.
