Tip & How-To about Computers & Internet
Barcodes can be printed symbols encoded information printed
in black and white contain. You can use bar codes entering data into bar code -
the generation of the image software and print barcode using a normal printer
or a barcode printer. Printed bar codes are read by a barcode scanner that
reflected light rays used to decipher the code. Bar codes may contain different
information. You can change or a bar code can be adapted by entering the
information reviewed in the bar code - generation software.
1. Access your favorite browser and go to barcode generator,
barcode, bar code or soft (see Resources) can use a free barcode - generation
software.
2. Most sites that offer bar code - generation software to
present their application interface on their own pages. Enter the information
reviewed or custom code in the space you want, and "Generate Barcode"
button to click to create barcode images.
3. See the image of the barcode displayed on your computer,
click on the image to pop-up menu to display. Click "Save Picture As"
from the pop-up window, select the location where you want to save the image
and click "Save" next window to save the image in the selected
folder.
4. Connect the cable to patch your bar code scanner in its
corresponding port on the back of your computer. Keep the scanner about six
inches from the printed barcode, which focuses on the barcode and press the
button to scan the bar code. Look at the revised data upload to your computer
and check its accuracy.
