Tip & How-To about Cell Phones
When you connect two Bluetooth devices, you enter a code on
both devices. Sometimes the code indicates an error and you are unable to both
devices. To connect them again, you have the existing password to a different
set of reset.
1. Accessing the menu of your phone and select
"Bluetooth" option "Settings". Here are the devices that
are currently connected to the phone. You want the password to restart the
computer, click the Bluetooth icon in the taskbar tray of your computer. The list
of paired devices is visible to you.
2. Select the device to which the password reset. If you
restart your phone, there will be a "Delete / Reset PIN." If the
option is not available, just "remove" the device from the phone. If
you reset the password on your computer, right click the device icon and select
Delete.
3. Re-connecting the two devices. You will be prompted to
set a new password on both devices before a connection can be established. Set
the new password.
In order to find other Bluetooth devices, Bluetooth device A must be set to discoverable mode. When set to discoverable, Bluetooth device A will allow other Bluetooth devices to detect its presence and attempt to establish a connection.
You may set your discover setting off if you like (It is recommended that you turn it off when not using the Bluetooth). When the discover setting is off, no other Bluetooth device will be able to find it. Undiscoverable devices can still communicate with each other but they have to initiate communication themselves.
Usually the discoverable device will indicate what type of device it is (Such as a printer, cell phone, headset, etc.) and its Bluetooth device name. The Bluetooth device name is the name that you give the Bluetooth device or the factory name that originally was programmed.
With advanced devices (i.e. computers, smartphones), both users must agree on the Passkey and enter it into their device. The code can be anything you like as long as it is the same for both Bluetooth wireless devices.
On other devices, such as Bluetooth headsets, the Passkey stays the same. Refer to the product's manual for the default passkey. Most often, the default passkey is "0000".
