2002 GMC Yukon XL Logo
Posted on Aug 23, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
2002 Yukon XL - No Headlights
No headlights or bright lights. Turn signals work. Factory Fog Lamps work. All other electical works.
Anonymous
Level 2:
Scholar:
  • Expert 99 Answers
  • Posted on Dec 02, 2008
Anonymous
Expert
Level 2:
Scholar:
Answers
99
Questions
Helped
46426
Points
192
Check the headlight fuses in the engine fuse box compartment. Not sure if the lights have relays, but they will be clearly mark in the inside of the top cover for location.
Turn signal does not work with headlights on, fast blinking.
Check to make sure all bulbs are lighted and none are burned out, Check all light side, parking, brake, turn signal, headlight, bright and dim, interior lights, fog lights. 4-way flashers
2002 gmc yukon xl....dash lights dont work when you turn on headlights
change your internal dash bulb ,,it is behind your dash panel ,,should be easy to get to ..if that does not work have autozone read your electrical free and they will save you the headache
2answers
Toyota paseo headlights wont work
may be a relay or fuse or a faulty switch
98 corvette headlights not working
If you can verify current going out of the main dash switch towards the headlamps, then I would go relay hunting. My guess is the switch, since the brights and fog lamps work on demand (dimmer switch pulled).
4helpful
HOW DO YOU CHANGE THE BULBS OF THE FOG LIGHTS?
The fog lights on most vehicles sit directly underneath the headlight bulbs. The ballast and wiring work just like the headlights, so changing them takes not much time. The procedure to change the fog light is as follows:-- 1) Open the hood and reach down underneath the headlights to unplug the electrical plug from the fog light assembly. Squeeze the top of the release tab and pull the connection off the bulb's ballast. 2)Turn the fog light counterclockwise to remove it from the fog light housing. 3)Install the new fog light bulb.Then connect electrical plugs properly. 4) Test the fog lights by turning it ON. Thanks. you can rate this solution and show your appreciation.
1helpful
2answers
2002 Grand Am GT Headlights seem dim , fog lights dont work
Check at the headlight sockets for a bad ground.
Main headlights not working
Sounds like the head light relay is bad . Have you ever checked the headlight bulbs?
Top GMC Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a GMC Expert? Answer questions, earn points and help others
