Hi, I recently just installed this stereo into my caravan and I was having the same problem. After hours of googling I found a solution that may help. When you connect the yellow and black wires to your other wires that go to your battery or power source I didn't get anything until I connected the yellow and red wire together from the stereo and connected that to the yellow wire into battery/power source. Some feature to illuminate the stereo I. E. Radio, CD, time display etc needs that red wire and will also light all the button up and you can use the stereo fully.
I hope this helps someone and saves them a lot of time. I was new to this and knew nothing about installing car stereos, I assume this is probably the case for all stereos but for newbies like myself I hope this helps. Good luck.
Here is the manual it would help to install your device
http://www.jvc.com.au/JVCstores/PRODUCTS/357/ATTRFILE_File3/KD-G245-396%20Inst.pdf
Ifthis solution helpful/useful for you please rate the solution. THANKS FOR USINGFIXYA.
