MotorGuide STANDARD MOTOR REPLACEMENT PARTS SWITCHES AND COMPONENTSDescript Logo
Posted on Jun 26, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a brute 567 12/24 volt hand trolling motor... it was working fine yesterday and now it wont even turn on.... is it bad wiring plug???? cuz the battery is fully charged
john Benson
Level 2:
Sergeant:
  • Expert 185 Answers
  • Posted on Jan 01, 2015
john Benson
Expert
Level 2:
Sergeant:
Answers
185
Questions
0
Helped
55163
Points
584
You will need to check the 12/24 switch, constant/momentary switch, momentary push button. This is after you have made sure you have electricty to the trollong motor.
Anonymous
Level 3:
Brigadier General:
  • Master 3,301 Answers
  • Posted on Jul 05, 2011
Anonymous
Master
Level 3:
Brigadier General:
Answers
3301
Questions
0
Helped
1014089
Points
10058
Check the power switch for voltage,, short it across the pins and see if the motor runs, if it does, replace the switch
My motor guide trolling motor died . It was on the new boat that I bought in 2011 . Checked the breaker fuse and it's good, tested the wiring with a volt meter couldn't find anything. Could it be the micro...
do you have it hard wired to pos and neg or does it have the 3 prong plug in switch ..if 3 prong its for a 24/36 volt motor wont work on 12 volt less you have the 12 volt plug
Oct 16, 2013 • Boating
3answers
24 volt trolling motor (motorguide) not working. Have 24 volts at receptacle in hull of boat but when I plug in the trolling motor and check the volts on the plug, I only read 6 volts. Any idea whats...
You have a high resistance short either inside the wiring or the lower unit. This will cause a voltage drop. I would be very careful not to keep it connected too long cuz the battery is trying to keep up with the current demand and may explode.
2answers
I have a Motor Guide Brute 767, 67 lb thrust 24 volt trolling motor. It will only run at about half speed even with new batteries.
I believe you may have a bad low voltage circuit board problem. I do not think they make the board any longer but you may be able to convert it to work by bypassing the circuit board. I am working on one now.
The switch keeps burning out and the motor turns about one turn and then will not turn again. Motorguide Trolling Motor Brute,767 67 lb thrust 12/24 volt Hyper Drive
i think its time to strip this motor out,, it sounds like its has a short in the field coil winding,,as its pulling far to many amps,,,,
4helpful
2answers
I have a 74LBS thrust trolling motor that hasn't never in my opion worked right, I don't think its wired right to get the proper 24 volts, However I have took it loose and hooked it directly to 2 marine...
Here is a picture of the wire connection for 24 volt. Compare to yours is it correct? If it is, I wish you listed make and model I could of sent you the right picture diagram of you motor. Use this picture as a starting point. Test the wires through the motor testing for 24 volts. Again if I knew make and model I could show you exactly were. Last if voltage is correct all the way through. The motor is the last thing to tear down. If the brushes or armeture is damaged in anyway, or manufactured wrong, it would lead to power loss.
My heat and AC fan wont come on and all the fuses are fine
What I would do is pull the fan blower motor speed switch, plug the wires back into it while you're holding it in your hand, run the car, and check with a multitester and see if you are getting voltage at the switch. Should be something like:
High=12-14 volts
MHi=8-10 volts
MLo=4-6 volts
Low=2-4 volts
OFF=no voltage
If you get voltage but the fan still doesn't work, then it's either a bad ground, or the motor is bad. If you can access the blower motor wire connections(sometimes its easier to try this with it removed from the vehicle), then you could try jumping the blower motor at the wiring connection with a known good 12 volt source, and if you STILL can't get the motor to spin then it's seized up or it's just a bad motor. If you have the motor removed, try spinning the squirrel cage by hand. Is it stiff? Seized? Probably need a new one if it doesn't spin freely by hand.
Hope this helps!
3helpful
Need to know how to wire a motorguide 767 brute trolling motor
The white wire is the ground. The black wire is neg. and the red wire is pos.
Motorguide brute 567, 67 lb. thrust
you will probably find it is either a switch problem or your wiring this is a twist handle?
Top MotorGuide Electrical Supplies Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a MotorGuide Electrical Supply Expert? Answer questions, earn points and help others
