Question about Coship CDVB2000E
I live in Tahiti and have a coship N6760B digital set top box decoder with sky pacific smart card. I have a 2.3 metre satellite dish with Cband lnbf. From the digital meter point of view I got a really good signal but it did not show up on the coship decoder. Then all of a sudden it started to show up on the decoder. The only problem was it would show up as say 93% signal then it would disappear for several seconds and then show up again varying from 93 -98%. On the decoder itself at the front you would see the signal icon flash on and off as well. So then I asked Fiji tv to start the subscription to see what would happen. Because of the signal coming and going I thought I would change both end connectors of the cable which I did but with no difference. Then with the account activated I tried to do a channel search. While the signal flashed up it got about one third of the sky channels up plus the local fiji tv channel. Then out of the blue the signal stabilised on the screen to 92%, no flashing on and off but completely solid. I could see the fijitv channel but on the sky channels a message came up 'Smart card no access' even though the card had been activated. While I had a stable signal I would do a channel search to get all the channels. It would get to 10% of the channel search and then all of a sudden the signal of 92% would disappear and the channel search would go no further. when I go out of that screen to view the signal in the installation menu it showed up at 92%. So then I would do the same thing again. another channel search. After 10% of searching the 92% signal would cut out and the search end. I then emailed Fijitv about it and they said they will reactivate the card again. The satellite guy in NZ encouraged me to fine tune everything to get the signal to 100%. So with my wife watching the signal from the decoder the only thing I did was go out to unscrew the lnb to adjust it up slightly to get it closer to the 915mm recommendation. As soon as I moved it, only a few mm, I lost the whole signal on the decoder. So then I moved it back to its same position again but now cannot get a signal. I have tried to reboot to factory settings like before but to no avail. I pulled the power plug from the wall, restart the unit, where upon starting the signal icon on the unit comes up and the word 'good' flashes up. Then once it comes up on the TV it says no signal. To clarify a few things in this whole process not once did I move the dish. The only thing I adjusted was the lnb. Once I got a strong signal from the digital meter I didn.t move a thing. Every time the digital meter shows a good signal but the instability comes from the decoder end. Do I have a faulty decoder? What do you think. I'm pulling my hair out!!! Jason
Jason478. I would be surprised you are picking up the signal from the Spot beam which Sky Pacific uses. I do not believe even the spill is reaching Hawaii. Best to get a refund of your money as you will definitely loose the signal when the replacement satellite kicks in on Dec 2011. Be careful of the Sales people in Sky Pacific. http://www.intelsat.com/flash/coverage-maps/sat_foot.html?sat=IS-701%20at%20180%BA%20E&display=map&spot=0
Posted on Aug 05, 2011
How do i set up my LG43uh620v smart 4ktv for sattelite reception.i have a sattelite dish ariel plugged in?
Easiest way would be use the HDMI output from your Satellite Receiver box to your new TV. If you don't have a Satellite Receiver box at that location, you'll need to get one from your service provider.
Your TV will not interface directly with the dish - you need the equivalent of a cable box to decode the signals from the dish, select channels, etc.
Apr 22, 2017 | Televison & Video
What is a converter box for tv
A digital television adapter (DTA), or digital-to-analog converter [set-top box], or commonly known as a converter box, it is a television tuner that receives a digital television (DTV) transmission, and converts the digital signal into an analog signal that can be received and displayed on an analog television set. It may refer to over-the-air broadcast television signals received by an television antenna, or to cable TV systems which switched to digital cable. It normally does not refer to satellite TV, which has always required a set-top box either to operate the big satellite dish, or to be the integrated receiver/decoder (IRD) in the case of direct-broadcast satellites (DBS).
In North America, these ATSC tuner boxes convert from ATSC to NTSC, while in most of Europe and other places such as Australia, they convert from Digital Video Broadcasting (DVB) to PAL. Because the DTV transition did nothing to reduce the number of broadcast television system standards (and in fact further balkanized it), and due to varying frequency allocations and bandplans, there are many other combinations specific to other countries.
Feb 21, 2013 | Polaroid FLM-3232 Television
After hooking up a dish network system my volume quits woorking
I have seen this happen, working with a satellite dish. You may have to call your satellite service r for a reboot. Or you may pull the decoding card out and unplug the satellite box. Wait ten minutes, insert decoding card, plug the satellite box and power it up along side of the TV. If problems persist, replace the box. Thanks for asking and show all hands of support!
Jun 30, 2011 | Philips 47PFL7403D 47 in. LCD TV
Sky is saying there is no signal. Turn box off and on again. I have done this but still get no signal. I have freeview only channels on my sky box
Firstly, you don't get Freeview through your Sky box. If you are watching Freeview channels then it's from an aerial connection. If you are getting a 'No signal' message on your TV, the first things to check are:
1. Check that you have selected the correct input source on your TV. If you are using a 'co-ax' connection (standard aerial cable) you will have to select this manually from the remote. If you are using a SCART connection, all you need to do is turn the Sky box off and back on - but you've done this already.
2. Check the connection from your Sky box to your TV - disconnect it, check that the cable and connectors aren't damaged then re-connect it.
3. Check the cable between the dish and the Sky box. Unplug this from the Sky box and reconnect it.
4. Check that your viewing card is correctly inserted. This is unlikely to be the problem as it doesn't usually result in a 'no signal' message, but remove it and re-insert it anyway.
Finally, it's very windy tonight and this can affect the Sky signal if your Sky dish isn't properly secured. It's possible that your dish has been moved by the wind and is no longer aligned with the satellite. If none of the above work, you should inspect the dish as soon as conditions are safe enough to do so. If you can move it by hand, it can probably be moved by the wind.
Try these tests and post back and I will try to assist further if the problem has not been resolved.
Regards,
BElectric
If your problem has been solved, please be generous and award this solution 4 thumbs-up. This service has been provided FREE - your simple acknowledgement is appreciated. Thanks.
Nov 09, 2010 | Televison & Video
Hi I purchased a Sony 60 inch T.V model KDL60EX703U. It is supposed to have built in free view. I have set it up the same as my previous t.v however when searching for channels it does not find any. ...
When you are searching for channels check what setting the channel search is in this model had DVB-T DVB-C and DVB-T2, If it is in the wrong search mode it will not find the channels. Also does your sky decoder use a dish? if yes then this could also be the issue as the TV uses Terrestrial signals and the SKY decoder will use a Satellite System.
Oct 25, 2010 | Sony Televison & Video
Get dish network to work with hp SR5505F COMPAQ PRESARIO COMPUTER
You can not change channels on Satellite with your TV tuner card. The satellite box decodes the sat signal (it is sent encrypted) you can run S-Video/RCA/HDMI depending on the video card input, but you will be required to change the channel on the Dish box. The TV card can only change channels on broadcast (over the air) channels, you can attach an antenna and it will use the NTSC tuner to change analog channels (if they are still available) and the ATSC tuner to change digital/HD broadcast channels. This card (from your description can ONLY deal with broadcast TV, You will need a TV card with a QAM tuner for unscrambled digital cable. There is no solution for directly interfacing with Satellite on a PC or Mac (DirectTV or Dish) the signal from the satellite is encrypted and requires (at least for DirectTV, a fairly complicated decryption setup to function, this is handled by the tuner box/card combination. Sorry your setup will not support changing the channel on the PC, you may be able to find some kind of software that can utilize an IR transmitter to change the channels on your satellite box, similar to the way a Tivo or other DVR can talk to cable boxes, but that is the best you will be able to do as far as channel changing.
Jan 09, 2010 | HP Computers & Internet
Pay tv reception
Austar recently made changes that prevent the use of their smart cards in decoders other than Austar boxes.
Assuming you are using a legit Austar smart card, you will need to use it in the Austar decoder it was supplied with, for it to work now.
Apr 25, 2008 | Humax DRT800
Re-programming for Optus D2 satellite
what brand of set top box do you have?
Jan 24, 2008 | Coship CDVB2000E
Using an old SKY digibox for Freeview ?
you have a smartcard for that box ?, cause without that card, you won't see any of the channels at all.
Nov 11, 2007 | Televison & Video
Televison & Video Logo
929 people viewed this question
Top Coship Televison & Video Experts
Marvin
Marvin
Are you a Coship Televison and Video Expert? Answer questions, earn points and help others
