2003 Mitsubishi Outlander Logo
Posted on Jun 25, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need to rplace the inner tie rods. - 2003 Mitsubishi Outlander
Stewart Dibbs
Level 2:
Sergeant:
  • Mitsubishi Expert 415 Answers
  • Posted on Jul 08, 2011
Stewart Dibbs
Mitsubishi Expert
Level 2:
Sergeant:
Answers
415
Questions
0
Helped
147688
Points
716
Inner tie rods rarely if ever need to be replaced in my experience: outer tie rod ends are far more common. Its not impossible so here's how.
1. remove the tie rod ends from the knuckle.
2. remove the clamp for the rubber bellows on the rack ends, and slide the bellows down the rod.
3. Turn the rack to fullleft or right as needed to get access to the inner rod end that screws into the rack.
4. There's a lock tab that has to be bent flat. This locks the rod end into the rack.
5. You'll need a (probably) 32mm wrench to undo the rod end from the rack.
6. Note how the lock tab is fitted to the rack/rod end.
7. Put in the new tie rods.
If your garage mechanic told you the inner tie rods are worn out, I'd ask why they think so. At step 4. above, try rotating the rod. This should be quite difficult. There should be NO evidence of slop or wear in the inner joint. What more commonly wears is the bushes on the end of the rack. These bushes are easily replacable with the rack in the car.The tie rods have to be removed to do this. So, when the rods are off, inspect the rack bushes for wear.
SD
2helpful
2answers
Need to replace inner tie rod on a 1998 ford ranger two wheel drive , driver side . engine size is 2.5. do i have to take outer tie rod off as well?
webbraymond2, Yes, you have to remove the outer tie to access the inner tie rod. When you do this, count the rotations of the tie rod as this will have to be replaced when the new inner tie rod is installed. Counting the rotations will allow you to put the outer tie rod close to where it was when you started the job. You are changing the toe setting when you have to replace either the inner or outer tie rod. You need to access and remove the jamb nut and boot before you can access the inner tie rod and this is why the outer needs to be removed first. A wheel alignment is advised after you finish the job. Good luck with this.
3helpful
Inner tie rod removal
The first step in replacing the inner tie rod is to remove the tie rod end. It's basically a three step process, where you start by loosening the jam nut that's used to set the alignment (toe-in or toe-out). That jam nut determines how far up the inner tie rod the tie rod end is fixed. The tie rod end is hollow and threaded, so it can be screwed on or off the inner tie rod. Any procedure for removing a tie rod will start by telling you to count the turns you unscrew the tie rod end, something that I didn't do, and I'll save the explanation for the end:-) After you loosen the jam nut, you remove the cotter pin from the post on the outer tie rod ball joint, and unscrew the nut that holds the ball joint into the tapered fitting on the steering knuckle (video to right). After you pop the outer tie end free of the steering knuckle, you can unscrew the tie rod end. from the inner tie rod, but you need to grip it with something. Inner tie rods normally have some flat surfaces or a splined surface for grabbing with pliers. In this case, I needed two pairs of visegrips and a clamp to hold the visegrips on the inner tie rod from moving in order to get the outer tie rod end broken free and turning easy. That video is below. I happen to own the shop manuals for my Dodge Omni, so I was able to study the procedure for replacing the inner tie rod in detail. I didn't follow it for a couple reason. First, they show my type of power steering rack (Saginaw vs TRW) needs to be removed from the car to change the inner tie rod. That's a lot of extra work, not to mention the fact I buried one of the crossmember bolts in my unibody and flooring repair! So I went with an inner tie rod removal kit from Harbor Freight, manufactured by U.S. General (in Taiwan). The tool is very simple, basically a large steel tub with a snap in opening for a large crows foot insert on one end and a 1/2" socket drive on the other end. The kit is shown in the photo to the lower left (which I need to replace), and a video of the procedure is shown below. The kit wasn't quite right for my car, I had to use an oversized crows foot and the ball joint housing on the inner tie rod was too long, so the flats on the housing were barely held with the crows foot positioned by hand at the very end of the tool. But I got it out.
6helpful
How to install inner and outer tie rods on a 2004 Chrysler Pacifica - I waqs told buy a trusted local mechanic that I need to replace 3 of the 4 tie rods. Might as as well replace all 4, but how hard is it...
You will need to rent or borrow in inner tie rod tool but here are the directions.
1. Break the jam nut on inner tie rod to outer loose.
2. Remove nut from outer tie rod attaching it to steering knuckle.
3. Use hammer to get tie rod out of knuckle.
4. Unscrew outer tie rod then jam nut
5. Remove clamp from boot and slide off inner tie rod.
6. Using side cutter or hammer and chisel break off metal clamp on the inside of inner tie rod boot.
7. Using inner tie rod tool, unscrew inner tie rod from rack and pinion
8. Reinstall parts and have it aligned
3helpful
How too change inner tierod on 2005 pontiac g6
If you have electric steering(no power steering pump)you have to change the entire steering gear assembly as no part is available.If you have the system with a pump a part is available.In order to change the inner tie rod you would loosen the 21mm lock nut on the tie rod.remove the 18mm nut on the outer tie rod and spin off after removing the outer tie rod from the steering knuckle.Remove the nut and the inner and outer clamps on the tie rod boot.remove the boot.You would then need a special inner tie rod tool to turn the threaded inner rod from the steering gear.
2helpful
I need a suspension diagram that shows the Inner tie rods.
The inner tie rods are screwed into ends of the steering rack assembly.
Look at this diagram. #6 is the rubber boots and #7 is the shaft from the inner tie rods.
http://www.anubiscycle.com/fixya/2000-windstar-steering-gear.jpg
9helpful
How difficult to replace inner tie rod end on 06 silverado 2wd?
Not that hard, just spray the tie rod sleeve with WD40 night before and let it soak in. Remove the collier pin and and nut and hammer the old inner tie rod end out of the Track rod with a 5 pound sledge hammer. Remove the inner tie rod end from the sleeve and don't forget to mark the distance so you can place the new tie rod end at the same length. Reinstall the inner tie rod end to the Track rod and tighten the nut and replace the collier pin with a new one. Grease the fitting and go for a test drive, if the truck does not wonder then your good to go with out a alignment. Good luck and hope this helps, Note, make sure you have to right inner tie rod ends. Each side has different thread rotations.
1helpful
2answers
Replacing tie rods
Maybe just a tie rod fork ...you can probably get a loaner free of charge (just requires a deposit) from Auto Zone or one of the chain parts stores.
1996 chrysler concorde, how to take off the inner tie rod?
I used this website: http://www.allpar.com/fix/intrepid-steering.html It worked perfectly. To add to it, I used a tie rod puller tool rented from Oreilly Auto Parts for only a few bucks, to press the old bushing out of the inner-tie-rod end. Worked very well. Easier than removing the entire tie rod, and hammering it out. However, removing the entire tie rod would make re-assembly easier. If I did it again, I would strongly consider removing the driver side tie rod from the car, then attaching the inner tie rod end 1st. Meaning, attach the passenger side inner tie rod 1st, then the driver side inner tie rod with new bushing, then re-attach the drivers side outer tie rod. That would probably be the easiest way on this 1996 dodge concorde, due to the fuel line that's in the way....
1helpful
I need to replace the inner tie rods on my 97' conti......need a diagram of how to and any other info pertinent to the job - Bair
If this is a rack and pinion type steering, in order to remove the inner tie rods you will first have loosen the jam nut at the outer tie rod end,next unbolt the outer tie rod from the steering knuckle, unscrew the outer tie rod end off (be sure to count how many turns to remove), next remove the inner bellows boot (black boot) from the tie rod / rack and pinion, next is to unscrew the inner tie rod from the rack assembly (the do make a tool for this to make it easier) but if you do not have the tool,you can sometimes use a big pair of channel locks or a big enough wrench to fit on the fitting on the inside of the inner tie rod, and just unscrew the inner tie rod (normal left=loosen, right=tighten). Hope this helps. Would also recommend having it aligned after you are finished.
10helpful
2answers
I,ve disconected the tie rod end and slid the inner boot down the tie rod but can't figue out how to get the tie rod out?
If it is the inner tie rod you are working on it need to be threaded out on some you can get with a wrench but most you will need an inner tie rod tool. Look at your replacement tie rod you will see the threads and two flat spots that is where the wrench goes. Please rate.
Top Mitsubishi Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Mitsubishi Expert? Answer questions, earn points and help others
