I've run into this same issue. Although not a complete fix, I was able to program the tv with a basic universal remote. Try using the Goldstar remote codes. While I'm unable to use the channel buttons, I can change channels manually and turn the tv on/off and use the volume button. Again, not a fix, but a work around for now.
SOURCE: Westinghouse LTV-19W6 TV Won't change channels
I had the same the problem. My tv would not change channels. I had to run the tv through my dvd player to be able to view my cable channels. The one solution listed did work for me. Set your source to tv...press menu on your remote control...go down to the 4th icon...press the right arrow...move down to CH Auto Scan and press the right arrow. The tv will scan for channels and once complete I was able to change channels again.
SOURCE: Can't change channel using the remote or buttons on tv
Just run a channel scan, it should work after that.
SOURCE: my remote control for my polaroid tv wont change channels.
You may be able to program your cable box remote to control your TV in addition to your cable box. When they initially set up your cable box they probably left a pamphlet giving you instructions on how to program your remote. I'm not sure why you can't change the TV channels manually but this may give you a work-around.
