Kenwood KDC-MP332 CD Player Logo
Posted on Jun 25, 2011
Im trying to firgure out what the memory wire is. Everytime i cut my car off i have to reset all my stations and i have to start my cd all over again.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 12, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
44
Points
Its the yellow wire
How to wire a pioneer cd player to a olds alero 02 cut wires
Red is Positve = +
Black is negative = -
Yellow is the backup - If the backup is not connected, the radio station will lost it memory if ignition is turned off, and cd will start from no 1 and won't continue when it was last played. - Yellow must be connected to the Battery or positve wire which does not switch off if the inition is off
JVC KD-R312 CD player keeps resetting itself whenever the ignition is turned off. The radio stations are ok, but mybass, treble, loudness etc always resets itself. Is annoying because i ahve to go through...
You are losing the permenant 12VDC on the Radio. This is the thick yellow wire from the radio loom, it has to be connected all the time to 12VDC.
Cheers
I have a 1999 nissan sentra gxe limited edition and i put a kenwood aftermarket cd player in it and it wont keep memory do you know what the problem is cause the stock cd player kept memory
more than likey u dont have the memory wire wired correctly...chk the memory wire it should b an orange wire make sur eit is hookd to a continus power supply...if not then everytime u turn off the car it will reset..i have my memory wire wired with my red power wire
1helpful
2answers
How do you store radio station in memory?
you have the constant power wire and switched wire backwards.
Switch the red and yellow wires around.
Thanks for using FixYa - A FixYa rating is appreciated!!
JVC kd-s590
you need to have whoever installed the unit connect the YELLOW (memory) wire on the back to a constant 12 volt power source. It is hooked up right now to only have power when the key is on. this is why when you turn off the key, you loose memory.
what kind of car is this in... I can tell you what wire goes to what color if you cant figure it out.
Sony CDX-GT310 CD
The yellow wire must be directly connected to an always ON B+12 such as the + terminal of the battery. This wire is responsible for providing power to the memory.
Hope that this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sony car radio/CR/cassette doesn't hold pre recorded radio stations once ignition is turned off
run the yellow wire to the battery as its the memory wire and that will work if it is installed correctly and still does the same it can be the battery even if the battery still works.
Don't keep memeory
follow this code:
Black-----------ground
Red------------12V Switched (ignition)
Yellow---------12V (constant)
Blue------------power antenna
Blue/white----Amp turn on
Orange--------dimmer
White----------Left front+
White/blk-----Left Front -
Gray-----------Right Front+
Gray/blk------Right front-
Green---------Left rear+
Green/blk----Left rear-
Purple---------Right rear+
Purple/blk----Right rear -
In a grand-am the radios yellow goes to the cars orange and the radios red goes to the cars yellow.
1998 Pontiac Grand Am Stereo Wiring Constant 12V+ Orange Switched 12V+ Yellow Ground Black Illumination Gray Dimmer Brown Antenna Trigger Pink Antenna Right Rear Front Speakers 4" x 6" Doors Left Front (+) Tan Left Front (-) Gray Right Front (+) Light Green Right Front (-) Dark Green Rear Speakers 6" x 9" Rear Deck Left Rear (+) Brown Left Rear (-) Yellow Right Rear (+) Dark Blue Right Rear (-) Light Blue
Tuning Radio
Users manual is HERE.
The Constant +12 volt wire is the yellow one. Wiring connections begin on page 34.
Best of Luck.
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
