Broderbund American Greetings Creatacard Platinum 8 for PC Logo
A
Anonymous Posted on Jun 25, 2011
Disc 3 of CreataCard Platinum is broken and I cannot reinstall since my Vista had to be reset. It is still on my old XP but I don't know how to transfer it.
DJ Skywalker
Level 3:
  • Master 507 Answers
  • Posted on Jun 25, 2011
DJ Skywalker
Master
Level 3:
Answers
507
Questions
0
Helped
132422
Points
1597
Try to tranfer it to your other computer, using a USB-stick or External HDD.
* Copy the folder where the game is installed.
* Paste on USB-stick or External HDD
I've this didnt work, you need the cd's.
I run win7Pro & AG CreataCard Platinum 8 will not install..is my favorite card making program for family & friends, any help appreciated.
CreataCard Platinum 8 was written for XP and older versions of Windows. Changes in the OS make it difficult/impossible to install.
Do you have the 32-bit or the 64-bit version of Win7Pro? Click Start > Control Panel > System and Security > System. If the title reads Windows 7 Professional x64, it's the 64-bit version. (If it doesn't end with the x64, you have the 32-bit version.)
In any case, the best option is to try running an older version of Windows on another machine, a dual boot system or a virtual computer. With the Pro version of Win7, you can run a virtual XP for free (if your hardware can support it). Download and install Virtual PC and the XP mode package from Microsoft. (You'll need to set aside some memory for the virtual PC to run.) Then install CreataCard when running XP mode as if this is your only computer.
The only real problem is that you will not be able to have hardware installed on the virtual XP and the Windows 7 real machine at the same time. (So you can't share a printer.) Also, to share files between the two "systems", you will need to save them to external media (flash drive or optical disc, for example). Your motherboard and CPU need to support Virtualization. You have to turn this on in your BIOS on some systems. (Press Esc, F1, F2 or F10 repeatedly depending on your system right after turning on the system. If you miss the timing, shut down the computer and then retry.)
Other virtualization programs are Parallels and VMWare. However, with those programs and the other possible options for running CreataCard, you need a licensed version of the older version of Windows.
If you have the 32-bit version of Windows, you can try the Compatibility Mode. (Right click on the installer and choose Properties. Then click on the Compatibility tab and select Run the program as compatible with an older version of Windows. Apply the changes and click OK. Then right click on the installer again and choose Run As Administrator.) You may have to repeat this on the program icon after installing. However, the compatibility mode doesn't always work even if you have the 32-bit OS (and thus don't need the signed driver).
An alternative is to upgrade your software to one that is Win7 compatible. I'm not sure which of these Broderbund design and print products are most similar to CreataCard: http://www.broderbund.com/c-6-design-print.aspx . However, you will probably not be able to open old documents.
I hope this helps.
(XP mode is available with Win7Pro and Ultimate. At my house, we have two computers with Win7Pro with one running XP mode. At least once, the virtualization was turned off during a BIOS update and XP mode failed until the setting was corrected.)
1helpful
Is Broderbund Creatacard compatible with Vista?
In Vista, start the "Windows Program Compatibility Wizard".
Choose to install a "Windows XP" program, namely the Broderbund software. Vista will wrap a "cocoon" around the application, to fool the application into thinking that it is running under Windows XP, not Vista.
My OS is Windows Vista Home Premium. I have Am. Greetigs CreataCard Platinum 7. Does this not work with my OS? It seems to be "preparing for installation" a long time with no luck to run the program....
Start the "Windows Compatibility Wizard".
Select that you want to install a "Windows XP Application".
Point to the CD-ROM containing the software.
Install it by selecting the 'setup.exe' file.
How do I safely delete creatacard platinum 8?
Use the add/remove programs if you have XP, it's located in control Panel or Program Features function in Vista.
CreatACard Platinum 7 won't install on Vista Home Premium
If this is a new install from a new purchase, always give the manufacturer a call because they should know what it is compatable with and walk you thru most common problems.
1helpful
3answers
Printing CreataCard Platinum 7 with Vista
if there are they will be on their website, but i'm going to say you've probably made that software useless and will have to buy a new program
1helpful
I am getting a laptop computer. I have CreataCard Platinum 8
Vista has been a problem since it was introduced. Essentially Microsoft released it without ensureing driver were available for existing software and hardware. Some manufacturers have been making efforts to get Vista compatible Drivers available. Check the software websites for updated drivers.
3helpful
Creatacard Platinmum 6 won't work with Windows Vista.
CreataCard Platinum 6 is designed to be used with Windows 95/98/2000/Me or NT 4 and XP, therefore in order to run it in Vista I'd suggest to run your program using Compatinity Mode --> Go to your Desktop --> Right click on the program icon--> Properties-->Compatibility--> select one of the versions above
2answers
CreataCard 8 Platinum 8 DVD
It looks as though American Greetings has discontinued CreataCard which means they shut down the online content. There is no solution as American Greetings no longer supports the product.
The program is not compatible with Windows Vista.
Sorry for the bad news. Your English is just fine!
-WN
5helpful
8answers
Creatacard gold 3 won't work with Vista
I just installed Hallmark Comedy Card Studio by Sierra on my Vista 64-bit machine. It works with all the saved files from Creata Card. If the Calendar and Address Book data file is fmnot32.dat, rename it to planr32.dat and then the Event Calendar will work as well.
Top Broderbund Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
