Texas Instruments BA-II Plus Calculator Logo
Posted on Jun 25, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Error 1 or error 5 while solving for TVM problems.
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Texas Instru... Master 102,366 Answers
  • Posted on Jun 25, 2011
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10440340
Points
622693
According to the manual, error 1 indicates "Overflow", a number whose magnitude is greater than 9.9999999999999E99. Error 5 indicates "No solution exists", for example when FV, (N*PMT), and PV all have the same sign.
If you still have trouble, please feel free to reply to this post, giving sample problems producing these errors.
Tvm not working properly
It's a little tough to diagnose with what you've given. Could you post all the numbers you're putting in, the result you're getting, and the result you expect?
How do you find the fixed rate mortagage on TI 84 plus?
Use the TVM (Time Value of Money) solver. Press APPS 1 1. Fill in the known values, then scroll down to the item you want to solve for and press ALPHA ENTER.
Help using HP17 bII+ to solve for annuity?
If the interest is 1 percent per month, then it's 12 percent per year. Thus I/Y = 12. You're making monthly payments so P/YR = 12. With N = 48 and PMT = -632, I get $23,999.54 .
Select FIN from the main menu, then TVM. Press [SHIFT] [CLEAR DATA] to clear. Press OTHER, enter 12 P/YR and select END if needed. Press [EXIT] to return to the TVM menu. Enter 48 N. Enter 12 I%YR. Enter -632 PMT. Press PV to see the result.
7helpful
3answers
Asus P5VDC-TVM/s manual
Unless someone is kind enough to upload a copy of this manual, you'll have to buy it. Visit this website
Thanks for using FixYa All the Best!
1helpful
I would like some help in solving some TVM problems using the BA II Plus calculator. i.e. How to solve: I invested a lump sum of $2400 in an investment that returns 6% annually. How much will the...
2nd [CLR TVM] (clear TVM registers)
2 4 0 0 +/- PV ($2400 initial investment, negative because you're paying it out)
6 I/Y (6% annual interest)
1 N (one year)
CPT FV (compute future value, see 2544.00, the value after one year)
5 N (five years)
CPT FV (see 3211.74, the value after five years)
1 0 N (ten years)
CPT FV (see 4298.03, the value after ten years)
I would like step by step instructions on how to solve a simple TVM equation. i.e. I invest a lump sume of $2400 in an investment that returns 6% annually. How much will the investment be worth after ...
GOOD QUESTION, Patweetyp...
I've got you covered.
Seeing how it's been three weeks since you posted this there's a chance you've already gotten your answer, but let me go ahead solve this for those out there who may have had the same problem.
Background: There are FIVE TVM Keys; and as you would assume, you MUST input FOUR of them in order for the BA II Plus to solve for the fifth. Now let's get down to business.
1. Hit CLR TVM. [This is just a cleanup maneuver]
1a. Hit ENTER [yes, BA II Plus always needs to be told to store the value, ALWAYS]
2. Type in -2400
3. Hit PV [Since you are investing money at time 0, your present value is negative 2400]
3a. Hit ENTER
4. Type 6
5. Hit I/Y [Your annually compounded interest rate is 6 percent]
5a. Hit ENTER
6. Type 0
7. Hit PMT [you do not have any recurring deposits*]
7a. Hit ENTER
8. Type 1
9. Hit N [there is one year until expiration/liquidation/termination]
9a. Hit ENTER
10. Hit CPT
11. Hit FV [this is your ANSWER = 2544]
----- From here, all you would need to do is change N in order to get your other answers (5 years, 10 years, etc) ----
*If your calculation does not require a recurring payment then you really just have a basic equation of value which would be solved faster by hand. (IE, 2400*(1.06)^1=FV=2544).
You'll notice that I underlined "annually compounded" as well as "one year". The reason for this is because you ALWAYS need your interest term to match your time interval. For instance, if you had monthly payments of which you wanted the year-end total you would need a monthly effective interest rate, and N would be 12.
Okay, I hope that helped. The BAII Plus is the best calculator for time-value-money calculations I've come across. When things get more advanced, you will start using the amortization table which cannot be found in any other TI Calculator (from what I know). TVM is perfect for annuities, mortgages, loans, bonds, and more.
[email protected] for more questions.
TEXAS INSTRUMENTS = 1-800-TI-CARES...they are friendly.
I simply can not get the BA 11 plus to run a simple TVM calculation. Although I have the card, and feel that I am following the instructions properly, I always get error 5 code. What am I doing wrong?...
Error 5 indicates one of two conditions while doing a TVM calculation.
1) You tried to compute the interest rate when FV, PV, and PMT all have the same sign. Make sure cash inflows are positive and outflows are negative.
2) The LN input is not greater than zero during calculations.
The first is much more likely.
4helpful
How do I get to the tvm function on a TI-83 plus calculator?
Press the APPS key to bring up the Applications menu. Press 1 to select "Finance..." Press 1 to select "TVM Solver..."
How do i access the tvm solver
Through the Finance Application. Press [APPS][1:Finance][1:TVM-Solver] [ENTER].
Hope you find it.
72helpful
7answers
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Jerry Naidoo
Paul Bade
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
