This is the SMPS Power suply drive and the IC fails ONLY if there is fault in the circuit. You need to check on the SMPS section http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies Next you need to check if the LINE output transformer has failed. If so this will have a higher current drain and so switch off the SMPS unit. check for the EHT drivers, capacitors in the HT circuit.
check this link below for tips:
After 20 sec stendby
After 20sec on stennd by
