Smeg SUK91MFX5 Dual Fuel (Electric and Gas) Kitchen Range Logo
mike stringer Posted on Jun 25, 2011
Smeg suk91mfx oven not heating up ? Everything lights up and tryed new elements ?
5 Related Answers
douglas smith
  • 1462 Answers
  • Posted on Apr 01, 2007
SOURCE: Smeg main oven failure
problem is almost certainly the circular element. these sometimes fail with obvious damage but not always. check continuity across the element to be sure. you are right about element fixing. there is no reason why the design should'nt allow removal from the front as many do but i suppose the guys who make these things don't have to fix them.
Anonymous
  • Posted on Feb 15, 2008
SOURCE: cooker not heating up
removed broken element and replaced it. You have to access the fixing screws from the back of the cooker to remove it
Anonymous
  • 957 Answers
  • Posted on Apr 28, 2009
SOURCE: rear circular element not working
more often the element burns out before the selector switch. If there is an indicator lamp that illuminates when you turn it on and the light isn't coming on then it could be the switch.
Anonymous
  • 17 Answers
  • Posted on Jun 09, 2009
SOURCE: I have a smeg A2-5 oven and have been told it
Well it is very easy.
First and all diconnect the power cord.
The element secured by two 1/4" screw in the oven.
you have to pull Range out and go, emove the back panel and remove the element wiring connector, and you are ready to replace it with the new one.
Should you need more details please feel free to contact me. I can provide you wiring diagram and instruction booklet.
[email protected]
Anonymous
  • Posted on Aug 28, 2011
SOURCE: Hi Our Smeg SUK91MFX has either
Our stove will not grill
1helpful
Good Morning, I have a Smeg SUK91MFX and the fan oven does not heat up.
Hello Ron,
If you have already replaced the thermostat unit and both heating elements, and the indicator light is coming on and the fans are running, but the oven is still not heating up, here are some additional troubleshooting steps you could try:
  1. Check the wiring connections: Ensure that all wiring connections are secure and properly connected. Loose or faulty connections can prevent the oven from heating up.
  2. Check the oven control board: The control board regulates the power to the oven elements. If it is faulty, it may prevent the elements from heating up. You can test the control board using a multimeter or by having it professionally checked and repaired or replaced.
  3. Check the thermal fuse: Some ovens have a thermal fuse that protects the oven from overheating. If the thermal fuse has blown, it can prevent the oven from heating up. You can test the thermal fuse with a multimeter and replace it if necessary.
  4. Check the temperature sensor: The temperature sensor is responsible for monitoring the temperature inside the oven. If it is faulty, it may prevent the oven from heating up. You can test the temperature sensor with a multimeter and replace it if necessary.
If none of these steps resolves the issue, it may be best to contact a professional repair service or the manufacturer for further assistance.
Mar 02, 2023 • Smeg Ovens
2answers
Smeg SUK91MFX Oven. It gets hot to 140C but no further?
Question edited for clarity and add maker.
Question moved to Smeg.
Thermostat has probably failed.
https://www.google.com/search?q=suk91mfx+oven+thermostat+replacement
Jan 18, 2023 • Smeg Ovens
New (graded) smeg scp399x-8 no heat on any of the functions
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  • If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Apr 07, 2013 • Smeg Ovens
SMEG OVEN BRAND NEW WON'T HEAT
Sep 08, 2012 • Smeg Ovens
Fitting heat element sa410x
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
Feb 11, 2012 • Smeg Ovens
My smeg willl only work on the grill setting,. when I use the oven switch everything comes on but it does not heat up
1helpful
Smeg suk91mfx shelves not fitting anymore on oven.
buy a pack of 2 oven shelf guards from lakeland 10.99. cut them in half and slide onto the ends of the 2 shelves. works perfectly.
2answers
Smeg oven
  2. If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
If this helped like us on facebook please
How to Video Tutorials on Domestic Appliances
4helpful
4answers
Manual for Smeg SE398X
SMEG have all their manuals online. The SE398X series is at http://www.smegtech.com/site/smeg/myapp/libretti/index.php?model=SC110&lang=EN
Top Smeg Kitchen Ranges Experts
vince
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Smeg Kitchen Range Expert? Answer questions, earn points and help others
