Question about New Bright Toys
I just bought a New Bright Winter Belle train set used. It didn't come with instructions. We put new batteries in the ccoal car but it doesn't work
SOURCE:
bilink
  • 128 Answers
SOURCE: new bright 19.2v nicd battery problem
Don't throw away any NiCd power tool battery, Firestorm or Versapakbattery that does not hold a charge or does not give you the power youneed, you can get new life from your battery or device that containsNiCd batteries. icad batteries often die in such a way that they won't take a chargeand have zero voltage. This usually means they are shorted out bycrystal dendrite growth. You Can fix these shorted crystal dendrites by"Revitalization through Vaporization of Dendrites (RVD) Process".
You can get this guide from here
Posted on Jul 14, 2009
I have purchased 2 remote controlled toy cars from Costco over the years. These New Bright batteris and charges last only a few charges, and then they go bad. I am disappointed. I will go to Walmart and buy a new battery and see if it works better, if not, i will return to Walmart.
Posted on Dec 01, 2009
  • 14 Answers
SOURCE: Train powers up,lights go go.Press forward and it
The tender car supplies power from the track to the entire trian.
Make sure the train will run with just the Loco and the tender. Make sure the tender is securely plugged in to the Loco and make sure the the brushes under the wheels on the tender (this is how power gets from the track to the train) are in contact with the track. Finally use a scotch brite pad (DO NOT USE STEEL WOOL) to clean up the track a little.
You can also take a volt meter and measure for DC between the rails. You should have about 10.5VDC on the track. (Inside rail is neg on mine and outside is pos) ...
Hope this helps..
Bob
Posted on Dec 09, 2009
  • 5 Answers
SOURCE: New Bright Model #183 - how do I make the train
This train set is very particular and getting it to work each Christmas is a family tradition in frustration. First you must make sure that all the pieces of track are connected properly and that the track is perfectly symmetrical and flat. We double-check the battery positions every year and find one in wrong. There are + and - signs, but they're hard to see; use a flashlight. There is a black toggle switch below and behind the red stack that toggles forward (to make the train go forward) and backwards (reverse); straight out perpendicular to the train is the "stop" position. Also, you have to start at a stop/switch station. One other note: behind the red stack, there is a smaller black stack. If you turn this, you can make smoke come out of the stack. I think I remember someone suggesting a drop of cooking oil. Hope this helps!!! Hope you get it set up for Christmas!!!
Posted on Dec 24, 2009
  • 3 Answers
the battery isnt lasting because it needs to be fully discharged (drained) before it is recharged. (this is only for nicd batteries)
Posted on Feb 22, 2010
I need instructions for putting the train and track together
hi Joyce.
is this a electric train set or a battery set?
could you please give me more info on this please.
can you please tell me what train set this is.
or go to this link might help you out on how to put a train set together.
how to put train track together Google Search
Dec 01, 2017 | The Toys
Where to put batteries in wintersville express no 182 trains set
Buy a brand new one with instructions herehttp://aeif.scalemodel.net/fsid.aspx?id=131633602115&sid=2&c=487
The batteries have to be in the locomotive, and I would expect a removable door underneath or from the rear of the loco.
Nov 29, 2012 | New Bright Small Holiday Express Train
Hi having trouble with our new bright musical holiday station electric animated train set...very frustrating as one of the train tracks broke off a little part so no matter what my husband tries to do the...
Yes, additional track is available from several places, such as Hobbylinc.com, and TowerHobbies.com. At this time, just after Christmas, they are out of stock, however. Walthers.com has them in stock (1-4-2011). You can find extra track on sale on eBay, as well. Be sure to get the track with the brass covers, as New Bright sells battery powered trains that use bare plastic track, which will not work with the 384. A Google search will turn up more sources.
Dec 12, 2010 | New Bright 384 Holiday Express Animated...
I have a holiday train No. 181 which did not come with instructions. I can not locate where the batteries go can you send me instructions?
The batteries go in the first car following the lokomotive, the coal tender. There is a small black knob with a ****. Turn it, and it will open the top part, so you can put the batteries in. This train set will not take a rechargeable battery. Bummer...
Dec 09, 2010 | New Bright 181 Toy Christmas Train
Need train transformer model #APX663004
mcdevito75 here, Contact New Bright online at www.newbright.com for the transformer. Hope this helps. I didn"t see a telephone number at the site. Sorry.
Jul 13, 2010 | New Bright 384 Holiday Express Animated...
I need the controler for the SantaLand Musical Train Set
New Bright offers ONLY a 60 day replacement warranty after which there are no parts or service avaialble for this train set.
I would contact New Bright about a replacement or take it back to the store where you bought and select something other than New Bright products.
http://www.newbright.com/
Dec 02, 2009 | New Bright 384 Holiday Express Animated...
New Bright Model #183 - how do I make the train go? The light works when the engine switch is in forward and reverse, but the train doesn't move (wheels do not turn). The music plays from the coal are -...
Nov 27, 2009 | New Bright 181 Toy Christmas Train
Toys Logo
515 people viewed this question
Top New Bright Toys Experts
Colin Stickland
Colin Stickland
Jonah Oneal
gerry bissi
Are you a New Bright Toy Expert? Answer questions, earn points and help others
