When I try to store to or format a Secure Digital (SD) memory card, a write error displays. What should I do?
This solution was already tried without success. It appears to be in a Read-Only configuration and the write-enable slider has no effect. Is there a method to re-format the media at a low level?
The Secure Digital (SD) memory card has a write-protect switch on the card case. Like the write-protect switch on a floppy disk, the SD switch prevents the card from being written to. (The SD card is slightly thicker than the MultiMedia [MMC] card.) Moving the write-protect switch will allow you to write to and format the SD card. If you are looking at the front of the card, the switch is on the upper-left side.
please
