Zojirushi BBCC-V20 Home Bakery Traditional Bread Maker Logo
Anonymous Posted on Jun 24, 2011
My Zojirushi BBCC-S15 works even though the window blinks 8:00. Why is a battery needed?
Anonymous
Level 2:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
  • Expert 132 Answers
  • Posted on Jun 24, 2011
Anonymous
Expert
Level 2:
Mentor:
Answers
132
Questions
0
Helped
35859
Points
178
Some automatic breadmakers have a place for inserting batteries.
The intent is to create a memory back-up for two things:
1: The digitally-displayed clock setting, and
2: Personalized program settings you save to the machine to perform again later.
Now you're not required to install or replace the batteries in your breadmaker unless you desire these settings to be maintained long after the breadmaker is unplugged.
And, if you do decide to install or replace the batteries be certain to use alkaline-grade or better.
But be forewarned though: Breadmaker clocks don't adjust for DST (Daylight Saving Time)
Hope this helps!
Testimonial: "Seeing that this machine works well without a new battery, I'll enjoy it just as it is. Thank You!"
Zojirushi BBCC-S15 Bread Machine bought second hand. Works great, quiet and clean but odd chemical smell comes from drive motor. Removed the cover and everything is neat an clean inside. Smell seems to be...
Yes, Cosmolene, the protective waxy oil used to protect new military issue from corrosion. The coating on the motor windings and the 'fish paper' separators have a similar smell when heated. The motor may be drawing too much current and overheating. Make sure any opening that provide ventilation are clear.
https://www.google.com/search?q=Zojirushi+BBCC-S15+Bread+Machine+funny+smell
My zojirushi BBCC-S15 is working well even though the timer stays at 8:00 and this indicates the battery needs to be replaced. The machine does not signal any sounds during the different stages. Just what...
The battery is a back-up for the time display. Actual clock time, not the delay timer time. The battery also backs up any custom settings you created using the Homemade mode. Hope this helps.
1helpful
2answers
I have a Zojirushi bbcc-s15, and it started to leak from the bottom pan. The felt washer on the bottom has fallen off. Where can I find or how can I replace the outer and inner parts?
All those parts are part of the sealed bearing that is stamped into the bottom of the pan. Unfortunately they can't be replaced and you will need a new bread pan. Sorry Hank
Need new blades for Zojirushi bbcc-x20 bread
http://www.thegourmetdepotco.com/store/store_partaccess.asp?manufacturer=33&category=-1&search=BBCC-X20
Lost owners manual
The owner's manual is available from their web site at moz-screenshot-3.jpghttp://www.zojirushi.com/servicesupport/manuals/manual_pdf/bbcc_s15a.pdf
Need a replacement timing/driving belt for a Zojirushi BBCC-S15 bread maker.
I had great success in finding what I wanted for my breadmaker at http://breadmakerpartsemporium.ioffer.com/. They have manuals and parts for most breadmakers at very reasonable prices.
Zojirushi BBCC-S15 Flashing Lights won't reset
Reading my manual...the built-in lithium battery can be good for 4-5 years. The blinking"8:00 am" would indicate the problem. I am at that point now, but to send in the machine to fix it would be a challenge...
Susanna
Top Zojirushi Kitchen Appliances - Others Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Zojirushi Kitchen Appliances - Other Expert? Answer questions, earn points and help others
