Question about Eforcity for IPHONE 4 OS4 4G 16/32 GB LEATHER CASE HOLSTER POUCH
Iphone 4 error 3194 - Eforcity for IPHONE 4 OS4 4G 16/32 GB LEATHER CASE HOLSTER POUCH
  • florida Wilson
    florida Wilson Sep 12, 2018
    This will take a few time to fix this issues. Setup your iOS device and restore your backup. Start the iOS device setup process as if it were a new phone. You'll be given the choice to choose a backup from I Cloud or iTunes, or you can proceed with a fresh install and your iPhone error 3194 will be fixed. Still, anybody facing problem then they can go throughhttps://www.ipadsupportnumber.com/blog/f...
    and they help you out because I have faced the same problem that time they helped me a lot.
    New Friend:
    Problem Solver:
  • 14 Answers
It is seen that this issue occurs as iTunes don't have enough ways to connect to the Apple server because here the server is crucial for any updates as well as restore process. So, here we have presented top solutions to fix error 3194 code in Apple iTunes.
Fix Error 3194 Code in Apple iTunes Call 1 800 608 5461 Toll Free
Posted on Mar 28, 2018
    Master:
  • Eforcity Master
  • 307 Answers
This tutorial shows you how to fix iTunes error 3194: How to Fix iTunes Error 3194
Check it out.
Posted on Mar 19, 2018
    Habit-Forming:
    Scholar:
  • 36 Answers
ITunes Error 3194 occurs when your system is not able to connect with Apple,s firmware signature verification server. To Fix iTunes Error 3194, read the easy steps are given below:
Steps to Fix iTunes Error 3194:
Step 1: Close iTunes and open the open the hosts file on your computer and go to terminal from the utilities folder, then type sudo/nano/etc/hosts, and press ? Return. This will open the hosts file in a text editor.
Step 2: Now find the bottom of the hosts file to look at the Apple address at the bottom. Here a standard hosts file would not have any lines without a # at the front.
Step 3: Now look for a .74.208.105.171 gs.apple.com entry that will redirect the signature verification process to the Cydia servers. Owing to existence or nonexistence or that is producing the error.
Step 4: Now save the changes you made and your iPhone should now connect properly. To save successfully on Mac Press Ctrl+O to save and Ctrl+X to quit.
Step 5:Here you need to restore your iTunes and attempt your restore or update again. Because in few cases changes you did to your hosts file should allow you to proceed.
Step 6: Now keep your iOS device on Firmware update mode, especially when your iPhone is still not able to establish connection. However, make sure you have keep backup of your iPhone because iPhone will erase all of your device data.
Step 7: To restore your device connect the iOS device to your computer and switch it off. Then press and hold the power button and home button simultaneously for 10 seconds. After 10 seconds now release the power button but keep pressing the home button and you can see the message saying in iTunes prompting you to restore the iPhone.
After following these steps if you are still unable to Fix iTunes Error 3194, just call us 1-833-493-0111 for instant solution.
1 833 493 0111 How to Fix iTunes Error 3194
Posted on Dec 06, 2017
    Novelist:
  • Eforcity Expert
  • 78 Answers
Hi, This is probably too late but I really hope this can help you or others.
FoneDog - iOS System Recovery
software is the easiest solution so far that we put it on top to let you know that FoneDog- iOS system recovery fixes error 3194 without any data losses and compatible with all iPhone models, iPads and iPod Touch. Here are the steps on how to useFoneDog Toolkit:
Step 1: You need toDownload, Install and thenLaunch FoneDog -iOS System Recovery software
Step 2: Make sure that FoneDog - iOS system recovery detected your iPhone
Step 3: Proceed to "System Recovery"
Step 4: Confirm device in System Recovery module
Step 5: When the download is complete, the repair process starts
Step 6: You are good to go
More information you can see: How to Fix iTunes Error 3194 or iPhone Error 3194
Hope it can help you!
Posted on Apr 26, 2017
    Habit-Forming:
    Scholar:
  • 47 Answers
Generally, host file editing is useful to fix iTunes error 3194, you need make sure you did it right:
Step 1. For Windows, navigate to C:/Windows/System32/drivers/etc/ and find the file that's named "hosts". For Mac, the file is in /etc/
Step 2. Open the file in Notepad (or any other text editing software) (for Windows users, open this with Administrator Privileges). You'll mostly have this line at the bottom of the file: 74.208.105.171 gs.apple.com
Step 3. Either comment this line out by typing a single '#' (without the quotes) in front of the line (before 74) or remove the line entirely.
Step 4. Now, save the hosts file and then try updating your iPhone through iTunes. In most cases, the error shouldn't pop up now.
IF doing as above, still not working, you can change another iTunes backup recovery tool as an alternative. Personally, I recommend PhoneRescue to help you restore iPhone from iTunes backup.
Posted on Apr 21, 2017
    Scholar:
  • 108 Answers
  • Quit iTunes
  • Locate your hosts file, in Mac OS X this is /etc/hosts and in Windows this is c:\windows\system32\drivers\etc\hosts
  • Open the hosts file with Administrator privileges
  • Add the following lines to the very bottom of the hosts file:
  • 74.208.105.171 gs.apple.com
  • Connect your iPhone to the computer
  • Launch iTunes
  • Put the iPhone/iPad/iPod into DFU mode by turning the phone off and then holding down the sleep and power button for 10 seconds, then release the power button but hold onto the home button until iTunes tells you that the device is now in recover mode
  • Use the iTunes Restore feature as usual with the iOS device
  • After the process, remove the line you added to the hosts file.
Posted on Jul 03, 2011
SOURCE:
I wrote a text message to someone today and at the bottom of the message in a gray box popped the word Velkomin
Hi, you can try FoneDog iOS System recovery.
  • Fix with various iOS system issues like recovery mode, DFU mode, white screen looping on start, etc.
  • Fix your iOS device to normal from white Apple logo, black screen, blue screen, red screen.
  • Only fix your iOS to normal, no data loss at all.
  • Unfrozen your iPhone, iPad and iPod touch
Here are some articles for FoneDog:
Tips & Trick to Fix Your iOS System
iOS System Recovery Guide How to Fix with Various iOS System Issues
May 16, 2017 | Cell Phones
Error 3194 when i try to restore or update my iphone 4s ios 7.1
software is the easiest solution so far that we put it on top to let you know that FoneDog - iOS system recovery fixes error 3194 without any data losses and compatible with all iPhone models, iPads and iPod Touch. Here are the steps on how to use FoneDog Toolkit:
Step 1: You need to Download, Install and then Launch FoneDog -iOS System Recovery software
Hope it can help you! How to Fix iTunes Error 3194 or iPhone Error 3194
Sep 07, 2015 | Apple iPhone 4S
I have iphone 3gs 32 gb when i make software from pc by using itunes it show for me box "There was a problem downloading the software code 3194" how i can fix it plss
if you got a white screen and nothing else , the lcd digitizer is bad , did you drop it ?. try to do a reset put it in dfu mode while hooked up to the computer itunes should find it in dfu mode and follow the prompts to do a restore to factory settings , to put into dfu mode hold the pwr button about 2 seconds then push the control button and hold both down for about 10 seconds let go of the power button but hold down the control button for another 10 seconds , itunes will find it in dfu mode and do the above .good luck
Mar 18, 2014 | Eforcity Apple iPhone 3GS 16GB / 32GB...
My iPhone refuses to boot and when I followed an instruction posted here to connect it to iTunes and holding down the power and home button and letting go after 6 seconds, it told me to restore but when I...
Try unplugging it. And holding down the center button and the power button till the phone turns on.
It's stuck in dfu mode and the way to get it out is to just follow the same steps but hold till you see the apple logo
Nov 11, 2011 | Apple iPhone 3G
Please help me im in big troublle my ipod is not working since one month i tried everything what happend is my ipod is stuck in the apple logo (restart screen) and i tried restoring but the restoring...
Hey there.
I've googled around a bit for you and simply following this guide will very likely solve the problem.
If it does not work, feel free to contact me again.
Sep 04, 2011 | Apple iTunes
Phone doesn't start nor does iTunes restore, it just stuck on the apple logo start-up screen. On i tunes the error code 3194 shows up. what can i do ?
1. Open iTunes and connect the iPhone to your System (PC/Laptop).
2. Press and hold the Home button and the Sleep/Wake button at the same time
3. After exactly 10 seconds release the Sleep/Wake button. Continue holding the home button until you iTunes pops up a message telling you that it has detected an iPhone in recovery mode.
4. The iPhone screen will remain black
It may take a few attempts to get your iPhone into DFU mode. Generally, I hold down both buttons then release the Home button just before I think the Apple logo would appear. If you are still holding both buttons down and you see the Apple logo you are holding them down for too long
then try to perform the restore on itunes, if that did not work post a comment so I can assist you.
Mar 26, 2011 | Apple iPhone 3G
I have iphone 3gs , booltloader 06.04, baseband .05.14.02, OS 4.01... i accidentally upgrade its version to 4.1 after that i did downgarde to 4.01 using tinyumbrella n hactivate, jailbresk it using...
You can certainly jailbreak, but you cannot unlock as of yet. It doesn;t matter if you downgrade the 4.1 firmware, that may help you jailbreak but it is the Modem Firmware or Baseband that matters. Your baseband upgrade camme with the 4.1 update. Since you are at 05.14.02, you cannot unlock as of now, period. You cannot downgrade the baseband on a 3GS, so jailbreak using Limera1n or Greenp0ison, but you need to wait for a new version of Ultrasn0w in order to unlock for anything other than AT&T.
Dont worry though, my sources tell me that the unlock is on it's way to be released.
Good luck, contact me anytime.
EJ Kudelka
Nov 23, 2010 | Cell Phones
Cannot update or download apps on iphone 3G response says "Cannot connect to iTunes Store" had no problems first 9 months I owned phone...now this has been happenening for over a month. phone is jailbroken...
The problem with using a phone on another carrier is that even though it worked for a long period of time your current carrier updates information on there system and it may now have caught that you are using an unlocked phone on there service. This is not a bad thing but your applications may not work properly. You may also experience delayed voicemail and delayed text messaging because of this issue.
Apr 14, 2010 | Apple iPhone 3G
Eforcity for IPHONE 4 OS4 4G 16/32 GB LEATHER CASE HOLSTER POUCH Logo
171 people viewed this question
Top Eforcity Cell Phones Experts
Ken Scott
Level 1 Expert
Ray
Are you an Eforcity Cell Phone Expert? Answer questions, earn points and help others
