It could be two things. THe first are the elements. It is highly unlikely both resistive elements have failed simultaneously but it is possible. You can check these by first removing the elements and then use an ohm meter to measure the resistance across the terminals. If they are open then that is your problem. The second could be your oven controller. There are two contactors/relays that control the high voltage high current supply to your elements. These contactors are controller by a low voltage source. Your broil element uses a separate contactor than your bake element. Either both contactors have gone bad or the oven controller which sends the signal to close the contactor has gone bad. You can check the contactors by desoldering them from the PCB and applying the proper coil voltage. You should hear or feel the contact close. If you uncomfortable with these steps by all means call a repair man. If you do decide to try and take a peek make sure you unplug the stove first. Good luck!
Well i don't know if you are referring to me or not but I believe I gave you proper advice. The part you are referring to that you ordered is what I said the problem is. The timer IS the oven controller. Look at your part and read the following.
http://www.appliancepartspros.com/Applia...
See the two black devices near the middle, those are the contactors that I told you were bad. I did give you correct advice so I think I should be awarded the solution. And to clarify I never received money for your CORRECT solution.
The top of the back piece over the controls etc. should hinge up revealing fuses.
Make sure teh fuses are there, and that they aren't blown.
The didgital display works & responds to setting the clock & temperature but the oven burners on broil or bake do not respond and I can not find any fuses. when the command to bake or broil is engaged it sound like a breaker is engaging off & on.please advise.
The first FixYa,cost$12 dollars, help advisor suggested a fuse that coild not be located so I went ahead & bought the second advisor, which cost me $30 dollars, & was supposed to connect me to a real live person to call me back within 2hours which never happened. so the next morning I called a local Sears store in Great Falls, Montana and they a # 1(800)366-7278 for parts which I called & they have the part# 316 455 420 coming that will fix the kitchen range. Please put the $42 dollars Back in my account.
