Make sure you didn't bridge anything, knock anything off the deflection board you shouldn't have. All the resistor values on both sides of the STK match up, and most importantly Labeled all your plugs properly and placed them in the right spot, because if they are switched, you'll get a convergence issue. Make sure the fuses are still good too and that all the terminals that all the plugs go into have good solder joints.
Also, there is a voltage divider.
Make sure that none of the wires got loosened when you pulled this plug. (Particularly the ground wire) Let me know!
