SOURCE: not the float
Had a similar problem with a Wellworth after changing out all the replaceable parts. The new triangle gasket + nut kit was missing the flat anti-friction ring needed to allow the plastic nut to be hand tightened enough against the rubber gasket - without the ring the friction stops the nut turning, and you get a leak because there isn't enough pressure on the gasket. Retrieved the old ring from the trash & put it in - works perfect now! not sure if this is your problem too, but you might want to check the locknut / gasket tightness & seal.
