Re: I have p0700 and p0705 codes, p0455, p1125, and p2125...
P0700
The transmission of
a vehiclewhich has suffered a transmission problem will
send the P0700 code to the vehicle engine control module (ECM)
P0705 Transmission Range Sensor Circuit Malfunction
Possible causes
- Open or short park/neutral position switch circuit
- Poor park/neutral position switch circuit connection
- Misadjusted park/neutral position switch
- Park/neutral position switch may be faulty
P0455. A code p0455 most likely means one or more of the
following has happened:
A loose or improperly affixed gas cap
A non-conforming gas cap (i.e. not factory/original brand)
Other leak or damaged piece in EVAP system
P1125 Accelerator Pedal Position (APP) System
P2125 Throttle/Pedal Position Sensor/Switch "E"
Circuit
These codes appear to relate to your throttle poistion sensor(s) - check your throttle cable linkages and in particular the position sensor on the throttle body.
Circuit/System Description
The throttle actuator control (TAC) system uses two accelerator pedal position (APP) sensors to monitor the accelerator pedal position. The APP sensors 1 and 2 are located within the pedal assembly. Each sensor has a 5-volt reference circuit, a low reference circuit, and a signal circuit.
Two processors are also used to monitor the TAC system data. Both processors are located within the engine control module (ECM). Each signal circuit provides both processors with a signal voltage proportional to pedal movement. The processors share and monitor data to verify that the indicated APP calculation is correct.
DTC P0455: Evaporative Emission (EVAP) System Large Leak
The control module tests the evaporative emission (EVAP) system for a large leak. The control module monitors the fuel tank pressure (FTP) sensor signal to determine the EVAP system vacuum level. When the conditions for running are met, the control module commands the EVAP canister purge solenoid valve OPEN and the EVAP vent solenoid valve CLOSED. This allows engine vacuum to enter the EVAP system. At a calibrated time, or vacuum level, the control module commands the EVAP canister purge solenoid valve closed, sealing the system, and monitors the FTP sensor input in order to determine the EVAP system vacuum level. The following table illustrates the relationship between the ON and OFF states, and the OPEN or CLOSED states of the EVAP canister purge and vent solenoid valves.
Same 3 codes , p0455, p0442, & p2138 on my 2009 Chevy Impala and brought the car to a General Motor or Buick Dealer Service Department to replace vent solenoid or solenoid fuel tank evaporator control . Also replaced gas pedal position sensor.
There is a GM service bulletin on this particular item. basically covers both codes your getting. #07-06-04-019A: Intermittent MIL/SES, DTC P2138 with Reduced Engine
Power (Repair Instrument Panel (IP) to Body Harness Connector)
