Cars & Trucks Logo
Posted on Jun 23, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Tryin to hook up radio i have to run a wire to the ignition fuse just dont know where it is for chevrolet silverado 1500 ext cab 2wh drive sc1 model
Hans Pearson
Level 3:
  • Master 2,510 Answers
  • Posted on Jun 23, 2011
Hans Pearson
Master
Level 3:
Answers
2510
Questions
0
Helped
770549
Points
7758
To hook up a radio you should actually locate the Acc. wire that comes off the ignition switch. There must be a wire or plug in the area where the radio fits and this should supply current when the key is selected to Acc and beyond. Connecting the radio anywhere else could damage computer circuits or other electronic components.
1999 Chevrolet Silverado Why would my speedometer power windows and radio All stop working?i know its a fuse , just dont know which one
IGN KEY ON OR OFF, IS THIS A RAP FAILURE? KEY OFF? DELAY??????????????
WELL WE CHECK THEM ALL LACKING SERVICE MANUAL
I'D ALREADY BE DONE,. SILVERADO 1500 RIGHT? SO ALL ELSE WORKS, EVEN DRIVE TRUCK? HEATER BLOWER ON HIGH GOOD AND HEAD LAMPS ,? HUMMMMMMMMMMMM
POWER WINDOWS DEAD
2 FUSES BLOWN RAP OR IGNB./
OR BCM NOT HAPPY,. BCU RUNS WINDOW RELAY.
YEAS RAP RELAY KILLS DEAD THE RADIO TOO.
NEXT RADIO DEAD KEY ON DEAD, BUT POST DID NOT SAY IT.
RDO1 FUSE BLOWN, OR KEY OFF RAP DEAD.(OR WAITED TO LONG)
FUSE NAMED RADIO IS MEMORY TO RADIO ONLY.
NEXT UP SPEEDO DEAD. (THE GAUGE)
CLUSTER IS DIGITAL; MOSTLY
HAS 4 FUSE HERE THERE ARE
  • CRUISE
  • IGN-0
  • IGN-1
  • RADIO
NOT TOLD AT ALL IS KEY ON OR OFF?
NOR IF CAR DRIVES, NOR IF CLUSTER WORKS DRIVING
OR IF OTHER THINGS WORK OR NOT, BOTH.BOTH MATTER.
ALSO LEARN HOW RAP WORKS./
RAP IS this thing that allows things to work key off and a delay.
20 MIN RULE (
Retained Accessory Power (RAP) Circuit Description The retained accessory power (RAP) is a subsystem of the body control module (BCM). The RAP is designed to provide power to the following accessories when the ignition is in the run or accessory position, and up to 20 minutes when the ignition switch is in the off position.
  1. The power windows
  2. The radio
  3. The sunroof
  4. The overhead console
SO IS A RAP ISSUE CLEARLY.
USA ANSWERS ME ONLY UNLESS POSTER TELLS THE TRUTH AND NONE EVER DO.
EXPORT CARS ARE NOT THE SAME.
YES RAP CAN FAIL (KEY OFF FAILS) SURE BUT IS A WHOLE OTHER BALL OF WAX ,TESTING..
ask
1helpful
1997 5.7l V8 ext. cab. How can I replace ignition switch?
You will need to take the steering column apart to replace the switches. You will need specific tools to do it also.
Check this link:
1997 Chevy truck ignition switch replacement
DIRECTIONAL LAMPS 2009 1500 SILVERADO EXT CAB SHORT BED
I HAVE MY ANSWER ,AND I DID NOT PLAN ON PAYING FOR IT
2004 2500HD ext cab short box 6.0 L no 12V power
No there is not a inline fues. Have you hooked up the wiring to stud 1? It doesn't come from the factory hooked up.
2answers
MY 1995 SILVERADO 1500 EXT. CAB TRUCKS
sounds like your hydraulic clutch has failed. I would reccommend an internal inspection of your transmission by a mechanic.
I have a 2003 Chevy Silverado Ext Cab Z71, no sound is coming out
Seat belt and any warning chimes do not come from the radio, they usually come from a unit under the dash, what you are describing is probabl;y a blown fuse problem. I would checkfuses with a teat light as some fuses may not appear blown.
Top Chevrolet Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a Chevrolet Expert? Answer questions, earn points and help others
