Computers & Internet Logo
Posted on Jun 23, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I tried to open my jitbit macro lite but it keeps on saying that the program is running even though the playback was paused and the problem is I can't abort the playback since the hotkey that was assigned to it was also designated for another program. I'm stuck. I can't open the application anymore.
Anonymous
Level 2:
Sniper:
  • Expert 64 Answers
  • Posted on Oct 24, 2012
Anonymous
Expert
Level 2:
Sniper:
Answers
64
Questions
0
Helped
20415
Points
215
I'd recommend that you use Asoftech Automation macro recorder software instead, download it from
http://www.asoftech.com/ata/
2answers
Ok the manual didn't tell me much I just need to find out how to work the CD player on a sylvania scr4986. Can someone help me. I'd really appreciate it.
Basic CD Operation:
1. Power the unit ON if STANDBY mode by pressing the STANDBY ON/OFF(#3).The default
mode is RADIO,so press the FUNCTION button(#8) to switch to the CD mode.
2. Open the CD door by pressing the OPEN/CLOSE door release button(#9).Inset a CD with the
label facing upwards and close the door.
3. The unit will read the disc and display the total number of tracks found on the disc on the
display
4. To begin playback press the PLAY/PAUSE/BAND button(#1).The first brack on the disc will
play.
5. To pause playback press the PLAY/PAUSE/BAND button(#1) once more.Pressing again resumes playback.
6. Press the STOP button(#2) to stop playback.
7. Use the AL 1/VOL- or AL 2/VOL+ buttons(13,14) to adjust the volume level.
Advanced CD operation
1. Press the FWD/TUN+ button to skip to the next track.Press and hold to fast forward the
current track.Release the button to resume normal playback.
2. Press the REV/TUN- button to skip to the previous track.Press and hold to fast rewind the
Random playback
1. Press and hold the SLEEP/RDM button(#15) either during playback or in STOP mode for 2
seconds and then release.You will see the letters RDM appear on the display to indicate the
RANDOM mode in active.
2. If you enable the RANDOM function in STOP mode,press the PLAY/PAUSE/BAND button
to begin playback.If you enable the function during playback the next track will begin the
random order
3. To cancel the RANDOM playback mode,press and hold the SLEEP/RDM button(#15) for 2
seconds and release again.The letters RDM will disappear from the display to indicate the
function has been cancelled.
Repeat function
1. Before or during playback press the REPEAT/PROG button(#6) to repeat a single track
indefinitely.You will see REP appear on the display when active.
2. To repeat all tracks on the disc,press the REPEAT/PROG button(#6) twice(or once more if
you have already activated the repeat once function).You will see REP on the display blinking
to indicate the repeat ALL function is active
3. To cancel any repeat modes,press the REPEAT/PROG button(#6) once more(if in repeat all
mode or twice if in repeat once mode).The letters REP will disappear from the display.
CD program playback.
NOTE:You can only program a playback sequence while the disc is in STOP mode.
1. Press and hold the REPEAT/PROG button(#6).You will see P01 appear on the display to
indicate the program function has been initiated.
2. Use the FWD/TUN+&REV/TUN- buttons to select the track you want to play in slot No 1.
3. Press the REPEAT/PROG(#6) to store the selected track in slot 1.The display will now
display P02 to indicate your selecting the track for slot 2.
4. Repeat steps 2 to 3 for every track you wish to program up to a maximum of 20 tracks. If you
try to program more than 20 tracks the display will revert back to P01 and will overwrite the
first slot again.
5. Press the PLAY/PAUSE/BAND button(#1) to begin the programmed sequence playback.
6. Should you wish to cancel the programming you can press the STOP button to resume normal
function.
I use a nice little program called Audio Cleaning Lab by Magix. I usually get very good results, but sometimes, and increasingly, when I create the audio CD, the encoding goes haywire. It'll start out...
Id say its a driver or a hardware issue, I recently had a similiar problem with my soundcard, the sound would get worse and worse it was like you could hear raining from the soundcard. I had to switch to 4ch and back to 2ch to get the crackling and raining out. I haven't had the problem since I got new drivers for my sound card.
Id say there is noting wrong with the program, its most likely a driver or a hardware problem, try updateing your drivers and see what happens.
Thanks,
Ekse
1helpful
Video pauseing during playback
Dear jstevens6583,
try to download the right codec pack,
google search with keywords below:
'free download k-lite codec pack'
and search the link and click... find the latest version
and please make sure your hardware has enouggh RAM to run it.
GoodLuck!
Macros
After you record your macro do the following.
Open the excel file contains the macro. Go to tools and go to macro and click on macros. Select the macro you wish to add the close operation. Click on Step into... This will open up the visual basic editor. In the code window, at the bottom row you will see End Sub. Right before that row, type workbooks.close
Save the macro by clicking the save button. And you can run your macro to see if it works. I tried, it does :) Good Luck :)
2answers
How to playback a movie clip
press the bottom of the button surrounding the menu button.
2answers
Macro on excel
Macros are a timesaving feature that allow you to record a sequence of actions that you do in excel, and replay them back later.
You give each macro a name, and you can invoke them later, and Excel will "do" whatever it is you did when you recorded the macro.
To record a new macro:
1) Open Excel
2) Go to Tools->Macros->Record New Macro...
3) Type in a name for your macro and hit OK
(A new toolbar will popup with a "stop" button on it. Excel is now recording everything you do)
4) Do something, like, for example, select some cells and make them bold.
5) Click the "stop" button.
Now your macro has been recorded! You can play it back later by:
1) Open Excel
2) Go to Tools->Macros->Macros...
3) Select your macro from the list
4) Click "Run"
The actions you performed earlier will now be executed.
Macros are written in Visual Basic for Applications, or "VBA". It is a programming language which uses the Excel Object Model to perform various actions. You can edit and create custom macros by writing the code manually in VBA. To do this:
1) Open Excel
2) Go to tools->macros->macros...
3) Select an already existing macro
4) Click "Edit"
(The visual basic editor will open, showing you the code for your macro)
At this point you are writing a program in Visual Basic. To learn how to edit macros, you need to learn visual basic, as well as the specific quirks related to excel macros in visual basic.
Recording a macro, and then using it as a template while you edit it is a common trick for making macros manually more quickly.
If you are not familiar with VB, I would not suggest attempting to edit your macros in any but the most simplest of ways. If you're brave, you can try to learn about editing macros in VBA here:
http://www.anthony-vba.kefra.com/
1helpful
E03
my jvc gr-DVX MINIDV PAL KEEPS GETTING ERROR CODE EO3 PLEASE HELP
Even after using head cleaner, no playback
SOUNDS LIKE YOUR MAIN BOARD IS GOING OUT. NEED TO SEND IN FOR REPAIR
Top Jitbit Software Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Jitbit Software Computer and Internet Expert? Answer questions, earn points and help others
