SOURCE: LG Secret shows "unlock" on screen
Hi! I bought the phone yesterday, and as far as I can see, this "unlock" refers to the touch pad. When you press "yes" you should be able to to do things in the menu while the slide of the phone is closed. It locks itself again in a few secs (I think 5) so you have to unlock it again if you were idle for more than 5 secs. And I guess that could be personalized, to lock itself again in 10 secs or whatever. And if you want to use the menu without clicking all the time, try to do things with the open slide. Hope this helps.
SOURCE: LG Vu screen has frozen
It sounds like the touch screen/digitizer is broken This is the front of your phone that needs replaced. can be fitted by yourself if you buy ne onlne, prob not worth getting repaired by a repair centre if you are trading it in. You may be best selling it online for parts.
SOURCE: My touch screen won't work.
Try to turn off the cellphone, remove the battery for 5 minutes then re-insert the battery and try again. If the touch screen still doesn't functions try to restore the factory settings.
SOURCE: My LG GT350 touch screen will not work properly.
It might be a screen calibration problem, i am not familiar with that phone but i would call where you bought it, or call the manufacturers customer service phone line, find out if there is a way to calibrate it manually, if not try a hard reset they can also tell you how to do this and how to back up your data lg.com . if this does not help or work it might be a defective device and you should trade it in for a new one.
SOURCE: my touch screen is not
Your touchscreen is simply broken. This is not caused by software issues. If you have insurance on the phone, take it into a store to get it replaced.
-ex Sprint rep
