HP PHOTOSMART PLUS B209A All-In-One Printer Logo
Posted on Jan 05, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My hp b209a won't print due to a oxc19a0023 error. The touch screen is useless as all it will do is show the error number. everything is clean, cartridges are vented i've tried pulling the usb cable and power cables for 60 seconds while standing on my head and rubbing my tummy but nothing works.
303 Electronics
Level 3:
  • HP Master 370 Answers
  • Posted on Feb 04, 2019
303 Electronics
HP Master
Level 3:
Answers
370
Questions
0
Helped
404500
Points
2643
It could be a bad printhead or just some ink got on the electronics contact part of it. Check out the video to resolve this issue:
5 Related Answers
tom19511
Thomas Christopher
  • 1601 Answers
  • Posted on Jun 14, 2008
SOURCE: hp officejet 6300 will not print
try this:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01072463&cc=us&lc=en&dlc=en&product=1119598
If it doesnt work let me know, do not rate yet.
Anonymous
  • 11 Answers
  • Posted on Sep 10, 2008
SOURCE: HP Officejet All in One Printer "Cartridge Error"
Have you put new cartridges in?
pineworks
Clive
  • 4362 Answers
  • Posted on Jan 25, 2010
SOURCE: This is for an HP Photosmart 3310 all in one. The
Reset the product:
  1. Without turning off the product, disconnect the USB cable from the rear of the product.
  2. Remove the cartridges from the product.
  3. Wait for the 'Insert Cartridges ' message to display on the control panel.
  4. Disconnect the power cord from the back of the product.
  5. Wait 60 seconds.
  6. Reconnect the power cord. If the product does not automatically turn on, press the Power button (c01602202.gif ).
  7. Reinsert the cartridges, and then close any open doors on the product.
  8. If you receive a prompt to print a calibration page, do so.
  9. Reconnect the USB cable to the rear of the product, and then try printing again.
nblady
NIK
  • 206 Answers
  • Posted on Feb 22, 2010
SOURCE: HP 5440 printer will not print or test print
I had the same problem.I bought another printer.
Temporarily here is what I did. I used a USB cable that has lights. Whenever the print spooler jammed, the light would not be on. Then go to START, RUN, type in "CMD". This open a DOS window. Type "NET STOP SPOOLER". Wait for it to say it has stopped. Then type "NET START SPOOLER". It will start, then you can close the DOS window.
Unfortunately this helped only half the time. Some times I would reboot, only to have my job print on restart!!!!!
good luck
Anonymous
  • 4323 Answers
  • Posted on Jun 22, 2010
SOURCE: Try to print but: get General Printer error 0x61000f6 beware spam number 1*800*532*4187
Hi
This error comes due to carriage jam. Turn off the printer and unplug it from wall socket. Now, remove the cartridges and check for any dried up ink residue on cartridges on inside the carriage. Clean the cartridges contacts and carriage using a Q-tip dipped i alcohol. Let the carriage and cartridges dry before you plug in the printer.
Install the cartridges and check. If it still shows error then unplug the power cord coming to the printer without switching it off. Now, remove the rear door of the printer and check for any paper jams over there, remove if any. Wit for at least 15 seconds and plug in the power cord. Now check whether it is working.
Daniel Scott
Testimonial: "Thank you very much for the information. very helpful. I am sure this information will help other people as well. Thanks again. "
2answers
How TO Fix Hp Printer Error 0x610000f6?
Well known issue and easy fix
Error Code '0x610000f6' Message Displays for HP Photosmart ...
support.hp.com > ca-en > document
Error Code '0x610000f6' Message Displays for HP Photosmart Plus All-in-One Printers (B209a, B209b, and B209c) · Issue · Solutions · Solution one: Turn the printer ...
Different Ways for How to Fix HP Printer Error 0X610000F6
www.printerfixes.com > Brand Related Issues > HP
HP Printer Error 0X610000F6 also known as Carriage Jam Error occurs very often in the Photosmart HP Printers. When a jam occurs in the printer due to paper scraps or due to any other reason, the printer stops working and it doesn't print any document.
VIDEOS as well
https://www.google.com/search?q=Hp+Printer+Error+0x610000f6&rlz=1C1QJDB_enCA643CA644&oq=Hp+Printer+Error+0x610000f6
1helpful
HP Photosmart Plus B209a Black Ink Not Printing
You can try to put the printhead on hot water for some hours. Before you put the printhead back in printer you must dry it with towels to prevent short circuit and damage the printhead.
I hope to be usefull !
HP Photosmart Plus 209a-m doc in queue won't delete
using windows explorer, go into windows/system/spool/printers and erase contents in last item
HP 5600 printer won't print
Is your HP printer having printing problems due to incorrect printer configuration and driver installation? For the quick tech assistance, you can also go to the Printer USA Support, which is an online directory, offering the certified HP toll-free number that is helpful to directly get in touch with the technicians and get your printer problems repaired in no time. HP Printer Tech Support Phone Number HP Printer Help
6helpful
3answers
Can't print envelopes made by "Greeting Card Factory" v7 on an HP B209a-m. Cards (.fgc file) print OK but envelopes (.fev files) won't print (envelope won't go into the print area; spoolvs.exe take 99% of...
The problem centered around the fact that the HP209 would only print 8.5X11 sheets from Greeting Card Factory. Any other size seized up the pring spool.
We're going to return the HP (We think it's defective) and get an Epson.
1helpful
Ink systerm failure for hp Photosmart C6380 Oxc19a0023 Printer ask me to restart,but after I did several times, it still showing Oxc19a0023 code on the screen.
The ink failure error is caused by air in the ink feed tubes in your printer. This happens when the ink in your cartridge runs out and the printer sucks up air instead of ink. We have a step by step repair solution for this error posted on our web site at: www.ccl-la.com click on the printer repair pages and follow the links to your printer series.
I hope this helps, If so pleae rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
k24674
Grand Canyon Tech
Grand Canyon Tech
