JVC AV-48WP30 48" Rear Projection Television Logo
Anonymous Posted on Jun 22, 2011
Mt tv has a blue wave line in the top of the tv no matter which input it is on. I tried turnubg it on and off does not work. Is this a easy fix, ie cheap. Or get another tv fix. Thanks Ron
Anonymous
Level 3:
Top Expert:
  • JVC Master 14,553 Answers
  • Posted on Jun 22, 2011
Anonymous
JVC Master
Level 3:
Top Expert:
Answers
14553
Questions
Helped
2718560
Points
48227
Look like attached photo?
SD TECH
  • Anonymous Jun 22, 2011
    Yes
  • Anonymous Jun 24, 2011
    It is convergence problem and your set if you have some soldering skills is fairly easy to fix---I can tell you where to look and how to get at the parts.
    sd tech
tracy campbell
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 02, 2014
tracy campbell
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
207
Points
I have the same problem need help
1helpful
How to connect Panasonic TC-P50C2 to Bose Wave?
Connecting the audio between the cable box and the TV is easy, if you are using one of the composite or component video inputs. Just plug in the associated R/L audio jacks in a line with the video input. If you are using the HDMI input, that carries sound on the HDMI cable. You don't need to connect the audio out of the cable box to the TC-P50C2. See the connections page of the TV manual here: https://www.manualslib.com/manual/246619/Panasonic-Viera-Tc-P50c2.html?page=12#manual . Then set the TV to this input.
However, the Panasonic TC-P50C2 does not have an analog audio output. You could try connecting the cable box RCA audio out to the Bose Wave system. You will need a RCA M/M to 3.5 mm adapter cable. (Alternatively a RCA M/M to 3.5 mm F converter and an AUX (3.5mm M/M cable or a 3.5mm M to RCA F/F adapter with a standard RCA audio cable will work between the cable box and the Bose ) This may not have the audio sync correctly with the video.
The alternative is to use a digital to analog audio converter and one of the above RCA to 3.5 mm solutions. Get an converter that has an optical digital audio input and an optical audio cable (Toslink). (The cable isn't always sold with the converter.) (https://www.manualslib.com/manual/246619/Panasonic-Viera-Tc-P50c2.html?page=50#manual ) See some converters here: https://www.amazon.com/DA-Converters/b?ie=UTF8&node=3224445011 .
I hope this helps.
2answers
Projection HDTV Pansonic 47" Curving blue and green colors on top and bottom of screen.
You will need to replace your two convergence I.C.s.They are two large IC mounted on a large aluminum heat sink.Replace both,look for any burned resistors near them,replace those if needed,and readjust your convergence. Good Luck
Let me know if you need any further help
Why does picture have lines of different colors?
Common easy LCD TV fix: bad picture screen rainbow colors
? 4:04
https://www.youtube.com/watch?v=KWIWeESmXC0
Aug 10, 2014 - Uploaded by Tampatec
Common easy lcd tv service repair fix, TV's distorted rainbowpicture screen fixed by ... Common easy LCD TV fix: bad picture screen rainbow colors ... Need to report the video? ... Sanyo LCD with Distorted Half Picture Lines Waves Distortion Distorted ...Duration: 11:36. by Do It With Dave 316,733 views.
LCD Display Symptoms and causes. - YouTube
? 2:01
https://www.youtube.com/watch?v=DedJvyNm_s4
Mar 1, 2011 - Uploaded by Grants Pass TV Repair
With LCD TVs you can have the same display problems fordifferent ... Fix for Samsung lcd TV colour display problem - Duration: 1:26. by alwaysafix 462,823 views. 1:26. Sanyo LCD with Distorted Half Picture Lines Waves Distortion ... HOW TO FIX LED TV VERTICAL LINES ON SCREEN 55" MODEL LG ...
How To Fix A Broken Flat Screen LCD LED TV With Lines or ...
Toshiba Model 51h84
The wavy when cold is a issue with a board in the set--Hyper board--the warmup until it begins to work will gradually get longer and longer.
The blue: look at set on a unused video input--if see faint curved blue lines with some blue visable on the screen the blue screen control needs to be adjusted just slightly down until the blue and curved lines are not seen.
1helpful
3answers
I need to knowwhat phono leads I need to connect pc to tv -sound to come out of tv-Ive a medion pc? WHERE do I connect the leads on the pc?
Normally 3 standard sockets for audio, line in, line out and mic in, that are coloured blue green and pink respectively, for audio out connect to green socket (3.5mm jack plug)
2helpful
I have Cakewalk Music Creator 4 and EVERY time I launch it, I get a prompt stating "The following driver(s) either do not support the current audio format or are in use by another application. Please...
all you have to do to fix this is open music creator 4 go to options then audio click on the advanced tab and select mme 32(bit) then go to the general tab the click wave profiler once scanning your sound card close the wave profiler go to drivers and select your input driver (ie) line in/ mic line in, then the output driver (ie) speakers close the program re-open problem solved hope that helps
I have a blue wave on my screen
Solution:
Your TV has a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed in or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence or magic focus section.
Try to adjust the convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
Its a fairly easy fix on the Hitachi sets.
You can get a repair kit that includes all the parts from www.TvRepairKits.com. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc.
Everything you need to fix it yourself.
1helpful
2answers
Toshiba 57h81 green will not focus
Typically this is a convergence problem and can be repair relatively easy. Refer to this video to determine if you truly have a convergence problem. Also make sure you use your TV's original remote to make this adjustment.
Top JVC Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
 Grubhead
Grubhead
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
