SOURCE: Frigidaire wall oven FSC88W-5 The door is open
i have a feb386wech frigidaire wall oven that the left door latch came out and will not latch an stay in place
SOURCE: Oven stops working and display screen goes blank
Hello The control has developed faults in one or more of it's circuits. This clock/timer must be replaced to solve the problem. The Good news is that this is not one of the really expensive controls. Found this one for about 70$ at a website. Worth fixing- but beware the 'self-clean' function after repair, and this control should last a lot longer. Please acknowledge this post if info helps- have more if needed- Thanks- Ed
Testimonial: "Thanks for the great information. This WAS VERY HELPFUL."
SOURCE: Frigidaire gas oven, 5 years old, oven pre-heat
I don't have a solution, but I was wondering if it constantly beeps until you press the start button? I am having the same problem with my oven preheating. Until we can figure out how to stop this we unplug it and shut the gas off when not in use.
SOURCE: 1. Oven shuts down when
UNPLUG RANGE.
It sounds like you have a loose connection, and strongly suggest that you have a professional technician repair this unit.
SOURCE: I have an ES340 gas
Hello tds. It is not uncommon to smell gas when you open an oven door. That said, if the amount of gas you smell is stronger than it used to be call your gas company. They will send out a technician, free of charge, to check your stove. Joe
Thanks for choosing Fixya!
