I shattered the glasstop on my stove. I need to know how to replace it I have a GE Sprectra stove with the glass top broken and am considering ordering that part to replace ourselves. Is it possible? I also wondered what the black sealant is around the top.
Check your warranty in the back of your use and care book. If the unit was manufactured prior to 1/1/06 it may have a five year part (not labor) warranty as long as you did not physically abuse it. The glass top comes as an assembled top (glass, the black seal, and the metal frame holding it)
Disconnect power. remove screws under the front edge of cook top. lift cook top and remove crossbars holding burners up against glass top. Unhook cook top / frame assemble. Install new top in reverse order.
I cracked my stove top where can i order it and install it
Just a note when you're doing this... when you open up the top, put a towel across each side so that when you drop a clip, it doesn't go down the side between the oven and the outside wall. If it does, hope that it goes all the way to the bottom where you can get at it by removing the bottom drawer. If you put the towel all the way across the oven box before you start taking things apart, you also won't have to worry about where little tiny screws go when you drop them... and, you will drop them! ;-)
Also, the old tops had a reinforcement bar that the ground was attached to. The new ones don't. There's a tiny hole on the flange of one of the right hand burner holes... that's where the ground is supposed to go on the new top. You WILL need a smaller self tapping screw than the original one.
And, forget having a helper... get something to prop the lid open with that won't fall if you raise the lid a little while you're working on it. Helper will just get in the way and can't hold it still enough while you''re trying to man handle those tiny little clips and screws that hold the burners in place.
--Jeff Moden
I have the same problem - any recommended supplier(s) for the glass top assembly part?
I was just cooking on the range top and heard a loud pop. It was the burner I was using. Now what??
My glass top is shattered.
How do I order and install a new one?
Mine shattered too. Where to get replacement part?
replace ceramic top on stove
range top shattered when it got hot
broken glass top on GE profile
need to get part number, get the top ordered, and then will need help removing the original top
