Krups FLF2 Cordless Electric Kettle Logo
Posted on Jun 22, 2011
Kettle does not turn on - Krups FLF2 Cordless Electric Kettle
Calibrating kettle a 40 tsh model turn on kettle and turn knob to 10 and kettle wants to blow the steam valve my infra red gun says its only at 175
You cannot measure the flash steam as the pressure is greatly reduced the temp fall When vented. The temp inside kettle will vary depending on the pressure.
I turn it on and set it to 375. Why does it just keep blinking?
blinking green red light Electric Kettles Questions & Answers ...
www.fixya.com > Forum > Tags > blinking green red light
Electric Kettles blinking green red light questions and answers. Ask your blinking ...the kettle lights up but won't heat up, just bought it, the on switch shows red, but it isnot working...what to do? ... Chef's Choice 677 Cordless Electric Kettle.
red icon blinking Electric Kettles Questions & Answers - Fixya
www.fixya.com > Forum > Tags > red icon blinking
Electric Kettles red icon blinking questions and answers. Ask your red icon ... Light will not stop flashing Even after descaling and cleaning thoroughly the red lightflashes. Any ideas? ... "On" switch blinks, kettle won't heat Our 4-week old kettle juststopped working. When we ... Chef's Choice 677 Cordless Electric Kettle.
1helpful
On/off switch is BROKEN,HOW CAN I TURN THE KETTLE
Hanif, buy a new one because it will be difficult to find replacement and may even be costly. Kettles are cheap.
1helpful
Breville tea kettle won't turn on
anon.nick-20625 was right.
Opened the bottom of the kettle, not the charging base, using the three odd screws.
Found the white trip switch, which was a white line in the socket which connects the kettle to the charging base. Pressed it with a screwdriver and it came out more. Tested the kettle, works!
Hero
Fuse box turned off when switch on the kettle
kettle defected check for short or to many plugs on servie line try another plug
1helpful
I DO NOT HAVE COOKING INSTRUCTIONS FOR MY KPM-508 POPCORN POPPER
The instructions say make sure kettle motor is plugged in. Turn unit ON with switch on crown of machine. Allow unit to run for 3-5 minutes to heat up kettle. Turn unit off. Add 2 teaspoons of your favorite popcorn cooking oil to the kettle. Then add 1/4 cup of popcorn kernels to the kettle. Turn the unit on and close the door. When popping sound slows down turn the unit OFF. Flip the kettle over with the crank handle to empty the kettle. Repeat process until desired amount of popcorn has been popped.
11helpful
Hi there Hiw can I turn off the whistle on the Morphy Richards Accent kettle please?
You can turn off the electronic whistle on the morphy richards kettle by moving the switch (marked with a musical note) which is located underneath the electric base unit (not on the kettle itself).
New GE electric kettle causes wall outlet to stop working.
Your electric kettle in drawing more current than your wall outlet's are made for. Not being able to read your current draw on your GE kettle I would guess you have a bad GE kettle and it needs to be returned to where you bought it.
3helpful
My kettle does not turn off when boiling
this is more likley to be the switch its just a bimetallic type,when it gets hot steem on it it flicks the switch to turn the kettle off try giving it a realy good clean up inside around the switch it may just be lime scale blocking the vent hole
however normaly when the switch playes up its a new kettle
2answers
Kettle not switching off after boiling so carrys on boiling untill you turn it off
To state the obvious, the steam sensor has failed. Unless you are quite adventurous, and confident dealing with electrics, there's nothing for it but to get a new kettle (unless the kettle is still within warranty, in which case you should be entitled to a replacement of course).
Top Krups Kitchen Appliances - Others Experts
john h
Are you a Krups Kitchen Appliances - Other Expert? Answer questions, earn points and help others
