SOURCE: HP LaserJet 3030 Fuser Rollers
fuser roller is part of fuser assimble so you need to do is removed first fuser assy set aside and replaced the roller..tnx
SOURCE: HP Laserjet 3600 Fuser
google feedroller and go to their site they have the service amnual on the printer. you will need it if you never done one before.may as well check the corona wire while you are there.
SOURCE: Error 13.20.00 on HP laserjet 5200 jam inside top
This is a common issue and most times a bear to repair. There is a
sensor flag mounted on the paper feed assembly behind tray 1 which has
a habit of either coming off or the spring which moves it back a forth
comes out of its holder. In any case it is one of the worst repairs you
have to do. Many items have to come off to get to it and getting that
flag and spring on correctly even with the instructions is difficult.
Usually what will happen is you get the 13.20.00 error on power up with
no motor movement and when you open and close the top cover, the motor
will move but the same error reappears. If you are lucky it is just a
case of a shred of paper blocking the sensor flag from moving and worst
case of the flag having come off. You will need the service manual and
check the removal and replacment section on the paper feed assembly and
play close attention to the 3rd page.
sometimes this error also appears if a wrong fuser is installed in ur printer that is not ur model number.... have it checked
thank you
have a nice day
Testimonial: "Good answers - unfortunately still no closer to solving the problem."
SOURCE: how to replace fuser drive assembly on HP laserjet
http://www.feedroller.com/Store/Service%20Manual/HP%20LaserJet%20P3005%20Parts,%20Service%20Manual.pdf
Hi, this is a link to the service manual for this printer. It may help you with replacing the part
SOURCE: I have an HP Laserjet 5200 printer that prints
2 possible causes. Transfer roller problem....this is the roller that sits right under the toner cartridge and runs from left to right. Check to makes sure it springs back up when pushed down on both sides. Next is caused by dirty laser optics. This requires dis-assembly of the machine and should be done by a qualified tech. Dirty optics would be more of a concern in a dusty environment or if the printer has been used regularly for at least a year or more.
You are correct in assuming that if the problem was there before cartridge change and after with no change then the cartridge is not at fault.
