According to this website, How to Melt Chocolate in Crock Pot LEAFtv, the best way to get a gentle, even melt is to start it for 3-4 hours with the crock pot on, but then turn it off for 2 hours (with the lid on).
You can plan it out so that your transport time is part of the second 2-hour step with the heat off.
If it's cold where you are, I would transport the crockpot wrapped in towels, and inside a cardboard box. That will help keep the heat in, keep moisture out, and stabilize it in the car.
SOURCE: How do I get a
replace it for plastic can not be turned back to a clear state as it was when new
Sorry to give you the bad news
SOURCE: If I double a crock
Somehow this problem ended up under Vacuums!
However- I will pass along what my wife says: "Almost 2 times as long"
Same with Turkey in the oven-- She takes the weight, and multiply's the pounds by 20 minutes on the Turkey-- Thus twice as much weight takes twice as long..
I hope this helps-
If not-- try 'Kitchen' or something closer-- or try going on line?-- maybe compare 2 different sized crock pot recipe's of the same or similar meat?
Mack B
SOURCE: Is it possible to get
Although Rival does sell replacement parts, I could not find any listed for the model you have.
Perhaps you might like to look at their replacement parts webpage:
http://www.crock-pot.com/CustomerService.aspx?id=rpt
They also have a toll-free number, 1 (800) 323-9519.
Good luck from Detroit, MI.
SOURCE: I dropped it and need
Hi nebjcb,
There's an available replacement part that you needed at Crock Pot. Call their customer service at 1 800-323-9519.
Hope this helps.
Thank you for using FixYa.
