Nikon D3100 Digital Camera Logo
Posted on Jun 22, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What is the " fEE
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Nikon Master 102,366 Answers
  • Posted on Jun 22, 2011
Nikon Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10440628
Points
622693
You need to turn the aperture ring on the lens to its smallest aperture (largest f/number) and lock it. You can control the aperture from the camera body, the same way as on lenses without an aperture ring.
D3100 DOESN'T RECONIZE NEW AF-S 50MM 1.8G LENS
There are a series of small brass "buttons" on the outside bottom of the lens where contact is established. If a new lens, there may be some dirt or grease on them preventing contack. Wipe lens and camera buttons carefully with a lent free cloth and retry. Then it is time to go back to the seller.
Hi where can i get instructions on how to use my nikkon 50mm prime lens?
That depends on the lens in question.
50mm f/1.8 AF-D:
http://www.nikonusa.com/pdf/manuals/lenses/AF/AF50mm.pdf
50mm f/1.4 AF-D:
http://www.nikonusa.com/pdf/manuals/lenses/AF/AF50f1.4D.pdf
50mm f/1.4 AF-G:
http://www.nikonusa.com/pdf/manuals/lenses/AF/AFS50G.pdf
4helpful
I have a Nikon D3100 and want to buy a zoom lens 70-300.Please help I am confused is a Nikon AF Zoom-Nikkor 70-300mm f/4-5.6G compatible? And is it automatic focus?
That lens will work with the D3100, except for the autofocusing. In order to autofocus with the D3100, you need AF-S lenses, such as the AF-S VR Zoom-NIKKOR 70-300mm f/4.5-5.6G IF-ED or the
AF-S DX NIKKOR 55-300mm f/4.5-5.6G ED VR.
5helpful
I have a Nikon D40x and purchased the AF nikkor 50 mm f/1.8D lens a couple years ago, but find that it can only be focused manually. Is there any way to "turn on" the autofocus? I have not had...
Sorry, but the D40x lacks an autofocus motor, depending on the lens to have one. Nikon calls such lenses AF-S. This particular lens does not have such a motor, relying on the camera to have one. The only 50mm lens currently available with an autofocus motor is this one:
http://www.nikonusa.com/Nikon-Products/Product/Camera-Lenses/2180/AF-S-NIKKOR-50mm-f%252F1.4G.html
Earlier this week the Nikon web site listed a new 50mm F1.8 lens with an autofocus motor, but then it was removed. Hopefully they will officially announce this lens soon.
9helpful
I got this lens (Nikon AF NIKKOR 50mm f/1.4D) for my D3100 and it doesn't autofocus. I don't knowhow to intervene since there's no switch on the lens itself (because I understand it is small and it doesn't...
The D3100 can't autofocus with this lens. The D3100 does not have a focus motor, depending on the lens to have one. The AF-Nikkor 50mm doesn't have a focus motor, depending on the camera to have one.
To autofocus, you need lenses designated AF-S.
2helpful
LOOKING FOR A Nikon Normal AF Nikkor 50mm f/1.4D Autofocus Lens WITH VR.
There is no such thing. You can see a full list of current Nikon lenses at
http://www.nikonusa.com/Find-Your-Nikon/Camera-Lenses/index.page
You can see a list of current and old Nikon autofocus lenses at
http://www.bythom.com/nikkordb.htm
You'll see that no 50mm Nikon lens has ever had VR.
2helpful
I have a D90 Nikon, I mounted my Nikkor 50mm 1.8d
Make sure you set the aperture ring on the lens to its smallest setting (largest f/number) and lock it. Without doing so, the lens will not communicate properly with the camera and thus you will not get the autofocusing.
2helpful
'' Fee'' problem...
Turn the aperture ring on the lens to its smallest aperture (largest f/number) and lock it in place. If you need to, you can control the aperture by turning the subcommand dial (the one in front, under the shutter release button, unless you've swapped the dials).
2answers
On a Nikon D80, I get an fEE error on the display even with the lens' aperture locked at f/22 as required
Check to make sure that the tab is depressing tab on the left-hand side of the mount, when lens is facing you. Also check the contacts and clean them.
12helpful
FEE message in display when using 50mm lense
The FEE message indicates that the lens is not set to smallest aperture (highest number). The camera body expects this so it will have full control of the aperture. It sounds like you may be accidentally bumping or turning the aperture ring on the lens while using it or changing lenses. There is a little slide lock to lock it at f/22 to prevent this. Turn the aperture ring to 22 and move the slider so the white dot is next to the orange mark on the lens barrel.
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
