Well try the site below and order a drum cleaning blade and developer then once you have that get the service manual for this machine try this site Service manuals electronic components datasheets and equipment schematics...
for parts try this
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: meaning of code C04 ( EP 2030)
minolta cspro1054 turns off once you turn it on and code is c
SOURCE: how to clear M2 on minolta EP 4000/5000 cs/pro copier
clear web or drum count and developer,you will not effect the the machine aporation,by clearing count
SOURCE: Minolta copier EP 2030 error code C 04
No, in stand-by the exposure lamp should not switch on. What comes on in regular intervals is the heating lamp inside the fusing roler which can be seen from the exit side of the copies. The exposure lamp is under the glass and only comes on and print button is pressed and copy process begins.
GOOD LUCK.
SOURCE: code c 0200 minolta cs pro ep 2050
A c0200 deal with the scanner. You may have a blown scanning lamp. Dose the scanner find HP & does the scanning lamp turn "ON" it could also be the Lens HP. Was this code before or after you were there? If it was showing upafter you.. it could be that the Black Box is installed wrong.... Good Luck
SOURCE: minolta cs pro 2030 copier losing developer then jams
C000 is a main motor lock code. A developer change may help. It may be two seperate problems too. The fuser unit has some drive gears that tend to break and lock the machine. This is an old analog machine, you REALLY don't need to spend much money on this one.
