HP LaserJet 1200 Printer Logo
Posted on Jun 22, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Ther is a black line of 5 c.m. on the left side of the paper. I cleaned already the cartridge but it stays.
Anonymous
Level 2:
New Friend:
  • Expert 37 Answers
  • Posted on Jun 22, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
37
Questions
5
Helped
25187
Points
109
Dipend of a kind of black line, it could be a broken fuser film on the left side of the upper fuser roller.
1helpful
My Brother MFC-7420 Printer always prints black lines and splotches down the left side of my paper. This happens whether I'm scanning or printing from my PC. When I looked at my drum, it appears a
If you are seeing vertical streaks/black lines your primary corona wire is dirty and or the fax scanner may be dirty.
1)To clean the corona wire you take the drum unit and toner cartridge and place it on disposable paper to avoid spilling.
2) Clean the primary corona wire inside the drum unit by sliding the blue tab from right to left several times.
3) Return the blue tab and snap it into the home position.
4) Reinstall the drum unit and toner cartridge.
5) Close the front cover.
Caution: if you do not return the blue tab to the home position it may repeat the black lines.
3helpful
3answers
Printer: HP Laserjet 1010 model Black dots appear on the paper
Dots, Lines and smudges on the printouts are due to deteriorating cartridges and cleaning the green drum of the cartridge may help temporarily. Take out the cartridge and gently clean the roller/ green drum with a dry, soft, lint-free cloth wiping off the toner dots marks/ lines.
Also, make sure that the visible inside of the printer is clean and ther is no spilled toner inside, which sometimes results in dots.
Let me know if any further clarification/ assistance is required.
GoodLuck!
Dont forget to appreciate the solution if I could have been of any help!
CreativeTECH
3answers
Lines in printing
...maybe its time to replace fuser fixing film!?
Lexmark x1270 wont print color even though the cartridge is full.
A technique to improve print quality is to try and clean the cartridge nozzles. You may clean the cartridge by following the steps given below:
1. Go to the "Lexmark solution center." This can be done by clicking on "Start," go to "Programs" and Lexmark printer group. Click on the "Lexmark Solution center." Next click on the "Maintenance" Tab.
2. Select "Clean and Fix Horizontal streaks." Click on "Print". This will produce a printed page.
The colors that you should see here are black, yellow, magenta (a reddish purple) and cyan (a dark sky blue). You should notice the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right with no gaps.
If there are gaps in the lines or the print diminishes across the page, you should run the "Clean Print Nozzle" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below:
1. Please open the "Solution center" again and go to the "Maintenance" Tab.
2. Select "Install color/black cartridge" and remove the cartridge or cartridges from the printer.
3. Get a damp paper towel.
4. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.
5. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.
6. Next dab the cartridge on the towel to make sure that the ink is flowing.
7. Snap the cartridges back into the printer.
8. On your computer, select "Old Cartridge install."
9. Repeat the "Clean Nozzle Page" one more time. If this fails to address the problem the entire procedure may need repeating.
Next, try this printer self-test by following the steps given below:
1. Power the printer off.
2. Press and hold the "Paper Feed" button.
3. While still holding the "Paper Feed" button, press and release the "Power" button. Continue holding the "Paper Feed" button.
4. When the printer starts pulling paper, release the "Paper Feed" button. It should print a test page at this point.
5. Power the printer off, as this test is continuous.
The self-test should at least print out a set of either a solid black or solid color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, please try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with only a color cartridge installed (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed). If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, please let us know.
My printer is running a white streak through the center of pages
1. Turn the power to the printer "off."
3. Press the "Power" button once while continuing to hold the "Paper Feed" button.
4. Keep holding the "Paper Feed" button until one sheet is cycled through.
5. The test is continuous.
The self-test should at least print out a set of either a solid black or solid color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with only a color cartridge installed. (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed.) If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, let us know.
2helpful
2answers
Black line, 4-5 mm thick, down the page on printing, off centre
ok, both of those solutions are totally bogus....first, the quality issue...i build about 25 of these cartridges a week, and it sounds like you should check the life of the drum unit, if you haven't cleaned the corona wire already. ( refer to the printer documentation) Brother uses a seperate drum unit that will wear out after 12,000 pages, not the pickup roller. So if you have replaced more than 4 toner carts, it is likely, depending on your usage, that the drum unit is worn. Take out the whole toner/drum unit, remove the toner cart by pressing on the lever on the left front of the assembly and pull up and out. Now you should have two pieces. Look into the larger piece, and if you see excessive wear on the drum, it needs to be replaced. The jamming is a different issue, though....let me know if you need more info....don't buy a new printer yet!!!
Lexmark z715. paper comes thru with no ink in it. cartridge is full and appears to be installed oorrectly..please help
1. Go to the "Lexmark solution center." This can be done by clicking on "Start," go to "All Programs" and Lexmark printer group. Click on the "Lexmark Solution center." Next click on the "Maintenance" Tab.
1helpful
Feed paper light stays on, and paper doesn't feed through
hi im josh in cebu phils. friend if it stays lighted on and cartrdge move side to side. ther problem is in your paper feeder it wont detec the paper because maybe it is already covered with dirt and dust. try to clean it. good lcuk
32helpful
4answers
Hp Officejet 6310 All-in-one paper jam
Here's a video that shows how to clear a jam on this printer.
Black line
take out cartridge, look at he inside of machineis there toner on the left side of a thin glass, look at the fuser ( where it gets hot) are the rollers O.K. ?
k24674
Grand Canyon Tech
Grand Canyon Tech
