Whats the error cod c-d202 in bizhub c420?
Power off machine hold down utility key keep it held down switch machine on wait for the konica logo release finger off the utility key on the screen ttrouble reset will appear touch this on the screen then switch off the machine and switch back on this should clear the code if it does not ytou will need a technician to look at this
In Tech mode :
System 1
Initialization
Counter data fixing unit
Start button
Power cycle the copier
SOURCE: c5201 error konica minolta bizhub 420 i removed
reconnect again your fusing unit. then before you ON your machine you long press utility/counter then press the small circle black, then press trouble reset.off/on
SOURCE: how to reset fuser unit forkonica minolta bizhub
In tech mode :
System 1
Initialization
Counter Data fixing Unit
Start button
Shut off the copier ans switch on
SOURCE: how to reset fuser unit message for konica minolta
In Tech mode :
System 1
Initialization
Start button
SOURCE: konica minolta bizhub c300 how to reset fuser unit
you need to get a small pico fuse(small green resistor like part on wire harness in fuser. or if your fast you can remove the fuse and short the wires turn on the machine then count to 10 and unshort them. fuser will reset. this is the only way or get a new fuser (too spendy) write me back if you need help.
