i had the same problem with same speaker system. the amp for this system is inside the bass speaker. if your amp is still working but your bass speaker is not you could cut the wires to that speaker making sure the cut wires do not short out. i was quoted more to repair them than it was to buy a new set. but i wont be buying logitech again as ive had two lots fail.
Hi Haley, I also enjoy good Music and excellent sound from my speakers that i have and know what you going through. There is two problems that i see here. One is that your bass speakers is dying on you from the excess bass that has been exerted throught it or have you tried lowering the adjusting bass from the contol panel? Try adjusting the bass and if that doesnt work aleast you've identified your problem. Thanks Haley for using Fixya.Good Luck.
try swapping the speakers
around if the problem still persists either the speaker is faulty or the speakers plug/outlet is
usually at the back of the computer you will have to open up the computer
to check the lead attached to the rear of the input plug make sure the
connection is good or you might have to clean
the dust from your computer dust causes static which causes your computer to
overheat and all sorts of problems be sure to wear an anti
static earth strap before touching anything inside your computer try
cleaning your computer of dust using a fine air blower from a compressor making
VERY sure that there is no MOISTURE in the air line specifically around the CPU
central processing unit and your SOUND CARD dust causes static to build up in a
computer causing it to overheat any many other problems other than that you might have a warranty issue hope this helps
Make sure the wired remote is connected completely and if that doesn't work try putting a pillow or a pile of blankets to cover both the subwoofer driver and the air port on it and that should reduce the sound coming from it. Also if it is in a corner or on a solid floor like wood or tile i would move it to a less enclosed space with carpet or a rug. Thats all I got I hope that helps.
logitech rarely has replacement parts. and for this model is not for the u.s. distribution so youcan not even call u.s tech support for help. try ebay or craiglist. if the connector is not proprietary you might be able to get a electronic repair shop to repin the connector.
